Using parallel write with subset of processors
Pascale Garaud
pgaraud at soe.ucsc.edu
Mon May 9 14:51:10 CDT 2022
Hello
I am trying to understand what would be the best way to
use the library to write data that is contained in only a subset of the
processors in my communicator. (Specifically, my problem is that I have a
3D dataset, and would like to save only a slice of that dataset to file,
and the slice is contained in only a subset of the processors).
Is there a best way to do that efficiently? The code currently uses a
collective PUT_VAR_ALL to write the 3D dataset to file, but that would not
work for the slice (and hangs when I try).
I could just copy the whole data for the slice into a single processor, and
then do an "independent" write for that processor, but that doesn't seem to
be very efficient.
I tried to understand how to use IPUT instead, but I am very confused about
the syntax / procedure, especially given that all of the examples I have
seen end up using all processors for the write.
I am very much a beginner in this process so any help would be greatly
appreciated, thank you!
Pascale Garaud.
Pascale Garaud
Professor in Applied Mathematics
UC Santa Cruz, California
(831)-459-1055
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20220509/d73398e8/attachment.html>
More information about the parallel-netcdf
