Error building PNetCDF 1.12.2 with NVHPC 22.1 under CentOS 8
Carl Ponder
cponder at nvidia.com
Fri Jan 28 04:19:06 CST 2022
Ok this fixed the problem:
export SEQ_CC=`which pgcc`
The SEQ_CC setting isn't mentioned by the command
./confgure --help
Could you get it to list somehow?
I had to find it by looking at the messages in the script.
Subject: Re: Error building PNetCDF 1.12.2 with NVHPC 22.1 under CentOS 8
Date: Fri, 28 Jan 2022 03:16:00 -0600
Reply-To: Carl Ponder <cponder at nvidia.com>
To: Wei-Keng Liao <wkliao at northwestern.edu>
The value is this
ac_cv_mpi_compiler_base_MPICC=/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/bin/pgcc
ac_cv_path_ac_cv_mpi_compiler_base_MPICC=/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/bin/pgcc
ac_cv_mpi_compiler_base_MPICC='/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/bin/pgcc'
which I *think* is what I want, since I built OpenMPI to use the PGI
compiler.
The problem, as I see it at least, is that for the Utility programs it's
trying to use gcc instead:
checking for mpiexec... /home/cponder/WRF/PGI/105.OpenMPI/bin/mpiexec
checking for gcc... /bin/gcc
checking C compiler for serial utility programs... /bin/gcc
If I don't add the PGI inslude-paths, at least, then gcc doesn't use the
wrong ones.
Date: Thu, 27 Jan 2022 22:34:41 +0000
External email: Use caution opening links or attachments
Can you check the value of variable "ac_cv_mpi_compiler_base_MPICC"
printed in your config.log?
If it points to the PGI compiler, then configure.ac needs to be fixed.
Otherwise, config.log can help me to identify the problem.
Wei-keng
> On Jan 27, 2022, at 4:29 PM, Carl Ponder<cponder at nvidia.com> wrote:
> I can get around the problem by *NOT* setting the include-paths to the NVHPC compiler:
> # export CPATH+=:$PGI/include
> # export C_INCLUDE_PATH+=:$PGI/include
> # export INCLUDE_PATH+=:$PGI/include
> I can work with this, but haven't had to do it with the other libs that use the CC/MPICC etc. compiler settings for everything.
> Do you still need to see the config.log?
> Date: Thu, 27 Jan 2022 22:16:25 +0000
> From: Wei-Keng Liao<wkliao at northwestern.edu>
> To: Carl Ponder<cponder at nvidia.com>
> CC:parallel-netcdf at mcs.anl.gov <parallel-netcdf at mcs.anl.gov>
> Hi, Carl
> Please send me file "config.log". I will take a look.
> Wei-keng
>> On Jan 27, 2022, at 3:42 PM, Carl Ponder<cponder at nvidia.com>
>> wrote:
>> I'm getting this error:
>> /bin/gcc -I../../../src/utils/ncvalidator -o cdfdiff cdfdiff.c
>> In file included from /usr/include/stdlib.h:55,
>> from /home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/stdlib.h:13,
>> from cdfdiff.c:19:
>> /home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:60:17: error: two or more data types in declaration specifiers
>> typedef float _Float32;
>> /home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:63:18: error: two or more data types in declaration specifiers
>> typedef double _Float64;
>> /home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:74:18: error: two or more data types in declaration specifiers
>> typedef double _Float32x;
>> /home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:78:25: error: two or more data types in declaration specifiers
>> typedef long double _Float64x;
>> make[3]: *** [Makefile:847: cdfdiff] Error 1
>> make[3]: Leaving directory '/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src/utils/ncmpidiff'
>> make[2]: *** [Makefile:545: all-recursive] Error 1
>> make[2]: Leaving directory '/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src/utils'
>> make[1]: *** [Makefile:476: all-recursive] Error 1
>> make[1]: Leaving directory '/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src'
>> make: *** [Makefile:533: all-recursive] Error 1
>> I believe the problem is that it's trying to use the system-default gcc here
>> which is incompatible with all the NVHPC_specific paths that I'm setting for the overall build:
>> export CC=`which pgcc`
>> export CXX=`which pgc++`
>> export F77=`which pgf77`
>> export F90=`which pgf90`
>> export FC=`which pgfortran`
>> export MPICC=`which mpicc`
>> export MPICXX=`which mpicxx`
>> export MPIF77=`which mpif77`
>> export MPIF90=`which mpif90`
>> export CFLAGS="-fPIC -m64 -tp=px"
>> export CXXFLAGS="-fPIC -m64 -tp=px"
>> export FCFLAGS="-fPIC -m64 -tp=px"
>> export LDFLAGS+=" -L$PGI/cuda/lib64 -lnvidia-ml"
>> I'm guessing that the old compilers & old OS levels didn't enable these types so there was no collision during the compilation.
>> Is there a way to override the gcc default for the utilities? I don't see any such setting in the configure --help output.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20220128/e200bd24/attachment.html>
More information about the parallel-netcdf
