Path oddity in PNetCDF build/configure
Carl Ponder
cponder at nvidia.com
Sun Oct 24 07:30:03 CDT 2021
When I build PNetCDF with MPICC=mpicc and mpicc on my$PATH, I see this
during the configure phase:
ENV PATH=${PATH}:/usr/local/bin
ENV MPICC mpicc
checking for sed handling option -i ... /usr/bin/sed -i''
*checking mpicc under yes... no*
configure: error:
Specified MPI C compiler "mpicc" cannot be found under yes
PnetCDF requires a working MPI C compiler. Please specify the
location
of an MPI C compiler, either in the MPICC environment variable
(not CC variable) or through --with-mpi configure flag. Abort.
I can work around it by making the path absolute
ENV MPICC /usr/local/bin/mpicc
*checking whether /usr/local/bin/mpicc exists and is executable... yes*
But, based on the first message, I'm thinking there's an incorrect
path-search during the configure phase.
This is with PNetCDF 1.12.2.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20211024/166ee4ed/attachment.html>
More information about the parallel-netcdf
