New release of PnetCDF version 1.12.2
Wei-Keng Liao
wkliao at northwestern.edu
Fri Jan 15 05:38:53 CST 2021
Hello to the PnetCDF community,
The new release of PnetCDF version 1.12.2 is now available in
https://parallel-netcdf.github.io/wiki/Download.html
Below are some noticeable changes from the previous version.
* Resolve issue when using GNU Fortran 10.0.0 compiler. Compiler flag
"-fallow-argument-mismatch" will be checked and added automatically.
* Fix strict aliasing bug when compiling with -O3 flag.
* Fix NC_CLOBBER mode when the existing files are symbolic links.
* Fix various compile and link bugs when NAG Fortran is used.
Detailed changes from the previous release 1.12.1 can be found in
https://github.com/Parallel-NetCDF/Parallel-NetCDF.github.io/blob/master/Release_notes/1.12.2.md
Please report problems encountered to this mailing list or create
github issues at https://github.com/Parallel-NetCDF/PnetCDF.
Best regards,
Wei-keng Liao
More information about the parallel-netcdf
