Methods to deal with the problem of "Size of I/O request exceeds INT_MAX"
刘壮 liuzhuang at lsec.cc.ac.cn
Wed Sep 30 21:14:42 CDT 2020
    I have got a problem when using pnetcdf to output a large variable, and the error message is "Size of I/O request exceeds INT_MAX". I have tried the compiling option "--enable-large-req", but it does not work. Breaking the large variable into several parts and using "nf90mpi_iput_var" and "nf90mpi_wait_all" several times may solve this problem, but the code is inelegant. Is there a better way to deal with this problem?
    Thank you very much!
Zhuang
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20201001/3bc60513/attachment.html>
