[EXTERNAL] Burst buffer - blocking or unblocking transfer?
Wei-Keng Liao
wkliao at northwestern.edu
Wed Sep 23 22:03:28 CDT 2020
In the current implementation, flushing from burst buffer to stable file system
is blocking. I.e. ncmpio_flush and ncmpio_close are blocking calls.
To enable your suggested asynchronous flushing, new PnetCDF APIs are required
to support it, for example, a new API to initiate the asynchronous flush and
an API to wait for its completion. This is typically a standard way to support
asynchronous operations, such as the ones used by MPI communication and I/O.
As Rob mentioned that the ability to aggregate multiple small noncontiguous
write requests and later flush them by only a few MPI collective writes has
already shown a good performance improvement, we did not explore the feature of
asynchronous I/O. However, we are open to adding such feature, but usually
motivated when such demands come from our user community, like in this case,
and when users can provide cases (codes) that show flushing is expensive.
Wei-keng
> On Sep 24, 2020, at 5:33 AM, Sjaardema, Gregory D <gdsjaar at sandia.gov> wrote:
> A similar use case may be a client that writes a file-per-checkpoint-dump. Once the current checkpoint if finished, the client closes the file and then continues with the calculations. Does that file get moved over to stable storage at that point while the client is calculating, or does the client have to wait after each dump/close cycle.
> ..Greg
> On 9/23/20, 3:31 PM, "parallel-netcdf on behalf of Michael Laufer" <parallel-netcdf-bounces at lists.mcs.anl.gov on behalf of michael.laufer at toganetworks.com> wrote:
> Rob,
> I am referring to a case of an application (WRF, for instance) that is writing checkpoint files periodically (no reading involved).
> So my question is, once the application hands off the write request to Parallel-NetCDF with burst buffer and a quick write is made to the burst buffer, will the application continue to perform calculations or will it have to wait until the file is finally transferred to (slow) stable storage to proceed?
> Michael
> -----Original Message-----
> From: Latham, Robert J. [mailto:robl at mcs.anl.gov]
> Sent: Wednesday, September 23, 2020 9:59 PM
> To: parallel-netcdf at lists.mcs.anl.gov; michael.laufer at toganetworks.com
> Subject: Re: Burst buffer - blocking or unblocking transfer?
> On Tue, 2020-09-22 at 18:29 +0000, Michael Laufer wrote:
>> Hi,
>> In reference to the burst buffer feature introduced in v1.10.0:
>> When the burst buffer flushes to the (long term storage) disk, does it
>> do so in a blocking or unblocking fashion?
>> It appears to me that it is blocking, but I am not 100% sure. If that
>> is the case, why not use an unblocking (async) transfer?
>> This would allow the computation to continue while the data transfer
>> from BB to disk in running.
>> Please let me know if I am missing something.
>> Michael Laufer
> Parallel-NetCDF could definitely issue MPI_File_iwrite calls, but with what would it overlap that I/O? The replay from burst buffer log to stable storage happens when pnetcdf closes a file, waits for operations to complete, flushes data, or finds a read.
> In the first three cases, there is no operation we can overlap with the write.
> In the last case, we wait for the logs to replay so we read back data as the application expects it.
> The big benefit for using the burst buffer feature is to soak up tiny noncontiguous writes.
> ==rob
More information about the parallel-netcdf
