PNetCDF C++ API, and open() and close() NcmpiFile members
Norman, Matthew
normanmr at ornl.gov
Thu Dec 10 09:47:07 CST 2020
Is there a C++ API for PNetCDF? I see an API for C, but I can't find one for C++. The examples are helpful but not enough for using the C++ interface.
Specifically, I'm running into a problem where there is no open() or close() for the NcmpiFile class. It seems in the examples that I'm expected to do this only via the NcmpiFile constructor and destructor. However, the way I'm using PNetCDF, I need the file to stay open across multiple write calls, so it needs to be a class object in my wrapper class.
I tried assigning another NcmpiFile object to my class's NcmpiFile object to open a file, but it looks like the move and copy constructores are private instead of public.
Any suggestions on how to do this and where to find the C++ API?
-Matt
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20201210/0379e5ef/attachment.html>
More information about the parallel-netcdf
