1.12.1: undefined reference to `nc_get_var_text' etc.
Sebastian Schubert schubert.seb at gmail.com
Mon Dec 7 09:22:27 CST 2020
Hi all
I try to compile the NetCDF library with pnetcdf support. For that, I
first compile the NetCDF library without pnetcdf and then pnetcdf with
MPICC=mpiicc MPICXX=mpiicpc MPIF77=mpiifort MPIF90=mpiifort ./configure
--prefix=/programs/intel-2019.5/pnetcdf/1.12.1 --enable-netcdf4
--enable-shared
using the Intel compiler suite 2019 update 5. All tests were successful.
Now I try to recompile NetCDF with pnetcdf support. The configure script
fails, though, running
mpiicc -o conftest conftest.c -lpnetcdf  -lhdf5_hl -lhdf5 -lm -lz -lcurl
with conftest.c being
#ifdef __cplusplus
extern "C"
#endif
char ncmpi_create ();
int
main ()
return ncmpi_create ();
   return 0;
The error:
/programs/intel-2019.5/pnetcdf/1.12.1/lib/libpnetcdf.so: undefined
reference to `nc_get_varm_ulonglong'
reference to `nc_put_att_uchar'
reference to `nc_put_vara_uint'
Obviously, this refers to the NetCDF library. Adding -lnetcdf fixes
this. However, I get other errors during the compilation.
Now the strange thing is that I was able to compile everything with a
more recent version of the Intel compiler using the very same approach.
Do you have any idea what is happening? Sorry if I did something stupid...
Thanks a lot
Sebastian
