New release of PnetCDF version 1.11.2
Wei-keng Liao wkliao at eecs.northwestern.edu
Mon May 13 18:50:13 CDT 2019
Hello to the PnetCDF community,
The new release of PnetCDF version 1.11.2 is now available.
https://parallel-netcdf.github.io/wiki/Download.html
This version is a bug-fix release. The bugs affected only the
building process of NetCDF-4 feature. If you do not enable
this feature explicitly (with configure option —enable-netcdf4),
then it is safe to skip this version.
Detailed changes from the previous release can be found in
https://github.com/Parallel-NetCDF/Parallel-NetCDF.github.io/blob/master/Release_notes/1.11.2.md
Please report problems encountered to this mailing list or create
github issues on PnetCDF repo https://github.com/Parallel-NetCDF/PnetCDF.
Best regards,
Wei-keng Liao
