[parallel-netcdf] #42: MPI-agnostic "ncmpidiff" tool?
Wei-keng Liao
wkliao at eecs.northwestern.edu
Tue Jun 11 13:05:09 CDT 2019
Hi Carl,
I have implemented a serial version of ncmpidiff, named "cdfdiff”.
It is available in PnetCDF repo and will be added to the next release.
https://github.com/Parallel-NetCDF/PnetCDF/tree/master/src/utils/ncmpidiff
Command “make” or “make cdfdiff” will create it.
Note it only compares the classic NetCDF files.
Let me know if it works with you.
Wei-keng
> On Jun 6, 2019, at 1:59 PM, parallel-netcdf <parallel-netcdf at mcs.anl.gov> wrote:
> Reporter: Carl Ponder | Owner: wkliao
> Type: feature request | Status: assigned
> Priority: minor | Milestone:
> Component: parallel-netcdf | Version:
> Resolution: | Keywords:
> Changes (by wkliao):
> * owner: robl => wkliao
> * status: new => assigned
> Comment:
> I use NetCDF's ncdump and NCO's ncdiff on head nodes.
> PnetCDF uses a lot of MPI derived datatype functions.
> I am not sure how much work is required to add the option
> you suggest, but can look into it.
> FYI, PnetCDF official repo has been moved to github.
> You can create new issues there.
> Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/42#comment:1>
> parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
More information about the parallel-netcdf
