Re: 【problems】ncp->format
Wei-keng Liao
wkliao at eecs.northwestern.edu
Fri Feb 22 12:15:33 CST 2019
Hi Toney
Can you run the following commands and send me the output on screen?
make clean
make ncmpio_attr.o V=1
Wei-keng
> On Feb 22, 2019, at 2:40 AM, Toney Zhang via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> When I follow the setps you have introduced in https://github.com/Parallel-NetCDF/PnetCDF/blob/master/INSTALL ,
> When I type `make` in the terminal, it always report the error such as the follow figure:
> <image001.png>
> Obviously, it’s an grammar error. However, I don’t know how to modify the source code, thus, I modify the output file ( follow ), and it’s well done.
> <image002.png>
> Hope you can modify the source code to make it work well.
> Thank you.
> P.S. I am a Chinese, and my English is not good. J
More information about the parallel-netcdf
