New release of PnetCDF version 1.12.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Mon Dec 9 16:45:57 CST 2019
Hello to the PnetCDF community,
The new release of PnetCDF version 1.12.1 is now available in
https://parallel-netcdf.github.io/wiki/Download.html
Below are some noticeable changes from the previous version.
* Resolve issue when using OpenMPI version 4.0.2 to build PnetCDF.
An error related to MPI constants that have been deprecated in MPI
standard 3.0 may occur.
* A new command-line option `-t` is added to utility program `cdfdiff` to
compare variable differences within a tolerance.
Detailed changes from the previous release 1.12.0 can be found in
https://github.com/Parallel-NetCDF/Parallel-NetCDF.github.io/blob/master/Release_notes/1.12.1.md
Please report problems encountered to this mailing list or create
github issues on PnetCDF repo https://github.com/Parallel-NetCDF/PnetCDF.
Best regards,
Wei-keng Liao
More information about the parallel-netcdf
