ncmpi_inq_malloc_max_size()
Max R. Dechantsreiter
max at performancejones.com
Sun Apr 7 18:44:47 CDT 2019
Every source file in examples/C calls ncmpi_inq_malloc_max_size()
(via pnetcdf_check_mem_usage), and this function is in the library:
308> nm -a libpnetcdf.a | grep ncmpi_inq_malloc_max_size
0000000000000080 T ncmpi_inq_malloc_max_size
U ncmpi_inq_malloc_max_size
309>
however the parallel tests fail in that subdirectory because
this function returns -222. Should one simply remove it by
for file in examples/C/*.c
do
sed -i '/nerrs += pnetcdf_check_mem_usage/d' $file
done
(for example), or is there another way?
More information about the parallel-netcdf
