issue with R8-> R4 conversion
Jim Edwards jedwards at ucar.edu
Thu Oct 18 11:49:21 CDT 2018
I am using the latest parallel-netcdf (svn revision 3824) and running into
a problem on an IBM pwr9 system with ibm xl compilers.
The issue is that writing a double-precision in memory variable to a single
precision file field results in NaNF in the file.   I tried the same
case using serial netcdf and the file was written correctly.
Any ideas?
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181018/9da1b11b/attachment.html>
