NetCDF: One or more variable sizes violate format constraints
Wei-keng Liao wkliao at eecs.northwestern.edu
Wed Aug 1 14:50:52 CDT 2018
I just now converted the test program to use nfmpi_
and it ran fine. FYI.
Wei-keng
> On Aug 1, 2018, at 12:37 PM, Norman, Matthew R. <normanmr at ornl.gov> wrote:
> Thanks for the quick reply. Yeah, sorry, the code I sent was mangled. It should've been nfmpi, not nf90mpi. Anyway, as you checked, the nf90mpi interface works, but the nfmpi interface appears not to. I'm not sure why that is, but I'm glad to have something working now. I switched everything over to nf90mpi, and it's good to go.
> Thanks,
> -Matt
> From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
> Sent: Wednesday, August 01, 2018 11:14 AM
> To: Norman, Matthew R.
> Cc: parallel-netcdf at lists.mcs.anl.gov
> Subject: Re: NetCDF: One or more variable sizes violate format constraints
> Strange. I was able to run the codes with 1.6.1 and below is from command ncdump -h.
> I am using gfortran based MPI compiler but having some minor problem when
> compiling your codes, particularly when calling nf90mpi_def_var.
> You do not need to specify the length of dimension ID array. Fortran 90
> checks that automatically.
> My code is attached. Please give it a try and let me know.
> % mpifort put_var.f90 -I$HOME/PnetCDF/1.6.1/include -o put_var -L$HOME/PnetCDF/1.6.1/lib -lpnetcdf
> % ./put_var
> % ncdump -h testfile.nc
> netcdf testfile {
> dimensions:
>        t = UNLIMITED ; // (0 currently)
>        x = 400 ;
>        y = 400 ;
>        z = 200 ;
> variables:
>        double t(t) ;
>        double x(x) ;
>        double y(y) ;
>        double z(z) ;
>        double hy_dens(z) ;
>        double hy_dens_theta(z) ;
>        double dens(t, z, y, x) ;
>        double uwnd(t, z, y, x) ;
>        double vwnd(t, z, y, x) ;
>        double wwnd(t, z, y, x) ;
>        double theta(t, z, y, x) ;
>        double windmag(t, z, y, x) ;
>        double ke(t, z, y, x) ;
>        double vort_xy(t, z, y, x) ;
>        double vort_xz(t, z, y, x) ;
>        double tracer1(t, z, y, x) ;
>        double tracer2(t, z, y, x) ;
>        double tracer3(t, z, y, x) ;
> Wei-keng
