Bug in ncmpii_sanity_check, version 1.8.1
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Nov 30 16:45:59 CST 2017
Hi, Greg
Thanks for catching the bug and yes 1.9.0.pre1 has fixed it.
I plan to release 1.9.0 soon.
Wei-keng
On Nov 30, 2017, at 4:19 PM, Sjaardema, Gregory D wrote:
> Not sure if you are still fixing bugs in 1.8.1 and I verified that it doesn’t exist in 1.9.0.pre1, so feel free to ignore…
> In the sanity test starting at line 166, there is the following block:
>    for (i=firstDim; i<(*varp)->ndims; i++) {
> #ifdef RELAX_COORD_BOUND
>         if (start[i] < 0 || start[i] > (*varp)->shape[i]) {
>             DEBUG_ASSIGN_ERROR(err, NC_EINVALCOORDS)
>             goto fn_exit;
>         if (start[i] == (*varp)->numrecs) {
>             if (api == API_VAR1) {
>                 /* for var1 APIs, count[0] is considered of 1 */
>                 goto fn_exit;
>             else if (count != NULL && count[i] > 0) {
>                 goto fn_exit;
> #else
>         if (start[i] < 0 || start[i] >= (*varp)->shape[i]) {
>             goto fn_exit;
> #endif
> The “(*varp)->numrecs” in the if statement at line 172 should be “(*varp)->shape[i]”  I think this is a cut-paste bug where two instances were changed, but the third was missed.
> ..Greg
