regression-test improvement in pre-release of PnetCDF 1.9.0
Wei-keng Liao
wkliao at eecs.northwestern.edu
Sat Nov 4 12:51:46 CDT 2017
Hi Carl
The building/checking progress messages reported by automake and
libtool are in different form. To minimize the report on screen,
you can use commands below.
make -s LIBTOOLFLAGS=--silent V=1
make -s LIBTOOLFLAGS=--silent V=1 check
The MPI error messages you are seeing are generated from OpenMPI
and they are harmless as we discussed this in our previous emails.
So, it is safe to ignore them. The rest of messages contain no
errors generated from PnetCDF. If a fatal PnetCDF error occurs, the
make or make check command will stop and report the errors on
screen. For example,
Making all in dispatchers
make[3]: *** No rule to make target `file.c', needed by `file.lo'. Stop.
make[2]: *** [all] Error 2
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Let me know if you encounter this kind of errors.
Wei-keng
On Nov 4, 2017, at 2:03 AM, Carl Ponder wrote:
> On 11/01/2017 07:04 PM, Wei-keng Liao wrote:
>> We are pleased to announce the preview release of PnetCDF 1.9.0,
>> parallel-netcdf-1.9.0.pre1, is now available for download.
>> We are sincerely soliciting feedbacks from the PnetCDF community
>> for this test release. The tar balls can be downloaded from:
>> http://cucis.ece.northwestern.edu/projects/PnetCDF/download.html
>> Below is a brief list of noticeable changes.
>> 1. PnetCDF has migrated to use automake and libtool.
>> 2. Support shared libraries. (ABI version starts from 1:0:0).
>> 3. NC_MAX_VAR_DIMS, NC_MAX_DIMS, NC_MAX_ATTRS, NC_MAX_VARS have been
>> lift to NC_MAX_INT for all classic formats
>> 4. Improved support for fill mode
>> 5. Support ARM architecture
>> 6. Update UTF8 encoding to use utf8proc v2.1.0 from the Julia Language project
>> 7. Build recipe for Unbuntu
>> 8. Address issues/bugs caused by MPI libraries (OpenMPI an MVAPICH)
>> Please note this is the first release of PnetCDF that officially supports
>> shared libraries. Problems may occur during the building and linking stages.
>> As always, please report problems encountered to this mailing list.
>> Detailed changes made since 1.8.1 are listed in
>> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-9-0-pre1/sneak_peek
> The pre-release fixes some error-messages that I'd been seeing with 1.8.1 and previous:
> ./nf_test -c -d .
> ./nf_test -d .
> MPI error (MPI_File_delete) : MPI_ERR_IO: input/output error
> *** TESTING F77 ./nf_test for CDF-1 ------ pass
> ./nf_test -c -2 -d .
> ./nf_test -2 -d .
> *** TESTING F77 ./nf_test for CDF-2 ------ pass
> ./nf_test -c -5 -d .
> ./nf_test -5 -d .
> *** TESTING F77 ./nf_test for CDF-5 ------ pass
> make[2]: Leaving directory `/cm/extra/apps/PNetCDF/1.8.1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf_test'
> ./nf90_test -c -d .
> ./nf90_test -d .
> *** TESTING F90 ./nf90_test for CDF-1 ------ pass
> ./nf90_test -c -2 -d .
> ./nf90_test -2 -d .
> *** TESTING F90 ./nf90_test for CDF-2 ------ pass
> ./nf90_test -c -5 -d .
> ./nf90_test -5 -d .
> *** TESTING F90 ./nf90_test for CDF-5 ------ pass
> make[2]: Leaving directory `/cm/extra/apps/PNetCDF/1.8.1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf90_test'
> This was using OpenMPI 1.10.7.
> I can't tell for sure that the equivalent set of tests is being performed, since the list is reported differently:
> make[3]: Entering directory `/cm/extra/apps/PNetCDF/1.9.0.pre1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf_test'
> PPF77 nf_test.o
> PPF77 nf_error.o
> PPF77 test_read.o
> PPF77 test_write.o
> PPF77 util.o
> CC fortlib.o
> m4 -DPNETCDF -I../../m4 test_get.m4 >test_get.F
> PPF77 test_get.o
> m4 -DPNETCDF -I../../m4 test_put.m4 >test_put.F
> PPF77 test_put.o
> m4 -DPNETCDF -I../../m4 test_iget.m4 >test_iget.F
> PPF77 test_iget.o
> m4 -DPNETCDF -I../../m4 test_iput.m4 >test_iput.F
> PPF77 test_iput.o
> F77LD nf_test
> make[3]: Leaving directory `/cm/extra/apps/PNetCDF/1.9.0.pre1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf_test'
> make[3]: Entering directory `/cm/extra/apps/PNetCDF/1.9.0.pre1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf90_test'
> PPFC nf90_test.o
> PPFC nf90_error.o
> PPFC test_read.o
> PPFC test_write.o
> PPFC util.o
> CC fortlib.o
> m4 -DPNETCDF -I../../m4 test_get.m4 >test_get.F90
> PPFC test_get.o
> m4 -DPNETCDF -I../../m4 test_put.m4 >test_put.F90
> PPFC test_put.o
> m4 -DPNETCDF -I../../m4 test_iget.m4 >test_iget.F90
> PPFC test_iget.o
> m4 -DPNETCDF -I../../m4 test_iput.m4 >test_iput.F90
> PPFC test_iput.o
> FCLD nf90_test
> make[3]: Leaving directory `/cm/extra/apps/PNetCDF/1.9.0.pre1/PGI-17.10_OpenMPI-1.10.7_CUDA-9.0.176/distro/test/nf90_test'
> This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
More information about the parallel-netcdf
