[parallel-netcdf] #30: Action prohibited on NC_GLOBAL varid
Federico Carotenuto carotenuto.federico at gmail.com
Fri May 26 09:34:51 CDT 2017
Dear Wei-keng,
Thanks to your suggestion I was able to work around the issue, just to be
faced with a different error about "Index exceeds dimension bound".
My code now looks like this:
ncstat = nfmpi_inq_varid(emisa_nc%id, 'Times', emisa_times_varid);
NCERR(__LINE__)
ncstat = nfmpi_inq_vardimid(emisa_nc%id,emisa_times_varid,dimidz);
NCERR(__LINE__)
write(*,*) "EMISA_TIMES HAS DIMID(1) = ",dimidz(1)
write(*,*) "EMISA TIMES HAS DIMID(2) = ",dimidz(2)
ncstat = nfmpi_inq_dim(emisa_nc%id,dimidz(1),dimchar1,lengttt1); NCERR(__LINE__)
ncstat = nfmpi_inq_dim(emisa_nc%id,dimidz(2),dimchar2,lengttt2); NCERR(__LINE__)
write(*,*) "DIMID(1) LENGTH = ",lengttt1
write(*,*) "DIMID(1) NAME   = ",dimchar1
write(*,*) "DIMID(2) LENGTH = ",lengttt2
write(*,*) "DIMID(2) NAME = ",dimchar2
ncstat = nfmpi_get_vara_text_all(emisa_nc%id, emisa_times_varid, &
 &   (/i2offset(1), i2offset(ihourrun+1)/), (/i2offset(dlen),
i2offset(1)/), datebuf)
NCERR(__LINE__)
It appears that the correct varable id for "Times" was actually 4 from the
Fortran point of view. "Times" have two dimensions: 1 to store the  time
itself in format "YYYY/MM/DD hh:mm:ss" (total length 19 characters), and 2
is the unlimited dimension time.
Now while dimension one with name "DateStrLen" has a correct length of 19,
the time dimension has apparently a length of 0, thus generating the
aforementioned error.
By checking on the file with other tools that dimension is unlimited but
should have length 3 in the file.
2017-05-26 14:14 GMT+02:00 Federico Carotenuto <
carotenuto.federico at gmail.com>:
> Dear Wei-keng,
> Thank you for your quick reply! Sorry if I'm replying via email but I
> can't find an option to reply to the ticket directly.
> I followed your suggestion and modified the source code in the following
> way, in order to echo the value of emisa_times_varid before NCERR
> write(*,*) "EMISA_TIMES_VARID =",emisa_times_varid
>          &   (/i2offset(1), i2offset(ihourrun+1)/), (/i2offset(dlen), i2offset(1)/), datebuf)
> write(*,*) "EMISA_TIMES_VARID AFTER =",emisa_times_varid
>           NCERR(__LINE__)
> In both cases, before and after the call to nfmpi, the value of
> emisa_times_varid is 0.
> As your links states that is effectively the NC_GLOBAL constant for
> Fortran.
> 2017-05-25 18:46 GMT+02:00 parallel-netcdf <parallel-netcdf at mcs.anl.gov>:
>>  Reporter:  Federico Carotenuto <carotenuto.federico@…>          |
>>  Owner:  wkliao
>>      Type:  defect/bug                                           |
>> Status:  assigned
>>  Priority:  major                                                |
>>  Milestone:
>> Component:  parallel-netcdf                                      |
>>  Version:  1.8.1
>>  Keywords:                                                       |
>> Changes (by wkliao):
>>   * owner:  robl => wkliao
>>   * status:  new => assigned
>> Comment:
>>  Hi,
>>  The Fortran constant NF_GLOBAL is defined in both NetCDF and PnetCDF as
>>  value 0.
>>  Its corresponding constant in C library NC_GLOBAL is defined as value -1.
>>  The variable ID returned from the Fortran nfmpi_def_var API should have a
>>  value larger than 0.
>>  You might want to check the value of emisa_times_varid right after the
>>  call to nfmpi_def_var.
>>  Do let me know if you got 0 for emisa_times_varid.
>>  The MATLAB may return a value that is C based.
>>  See definition of nf_global in the NetCDF Fortran header file from this
>>  URL[[br]]
>>  https://github.com/Unidata/netcdf-
>>  fortran/blob/master/fortran/netcdf3.inc#L96
>>  and PnetCDF Fortran header files from[[br]]
>>  https://trac.mcs.anl.gov/projects/parallel-
>>  netcdf/browser/trunk/src/libf/pnetcdf.inc.in#L161
>>  Wei-keng
>> Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/30#
>> comment:1>
>> parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20170526/01d7d25c/attachment-0001.html>
