Tests failure when building on i686
Bruno Pagani
bruno.pagani at astrophysics.eu
Tue Jun 20 14:10:20 CDT 2017
Le 20/06/2017 à 19:27, Wei-keng Liao a écrit :
> Hi, Bruno
> From file config.log generated on your i686 machine, it detected the size
> of MPI_Offset being 4 bytes, which is the cause of the errors you are seeing.
> This is related to an issue (bug) of OpenMPI recently discovered. See
> https://github.com/open-mpi/ompi/issues/3195
Thanks, subscribed too. ;)
Bruno
More information about the parallel-netcdf
