Tests failures with OpenMPI 2.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Tue Jun 20 10:36:55 CDT 2017
Hi Bruno
The link again contains the screen shot, not config.log.
Could you run command "ls config.log" to check?
The file "config.log" telle more detailed information about the build.
Wei-keng
On Jun 20, 2017, at 10:20 AM, Bruno Pagani wrote:
> Le 20/06/2017 à 13:13, Bruno Pagani a écrit :
>> Hi there,
>> I’m building PNetCDF on ArchLinux, with OpenMPI 2.1 that just landed in
>> our repos.
>> Building with 1.10.6 was fine, but with this new version they are
>> failures during the tests. I’ve uploaded both logs (for the tests part
>> only, tell me if you need more), first one is with 1.10.6, second one
>> with 2.1:
>> https://paste.xinu.at/m-IG5p/
>> What you want to look for in the second log is “stack smashing detected”.
>> Thanks for taking a look,
>> Bruno
> Additional config/build log: https://paste.xinu.at/o7h/
> Bruno
More information about the parallel-netcdf
