pnetcdf and mvapich2 2.2
Mark Dixon
m.c.dixon at leeds.ac.uk
Mon Feb 6 06:49:21 CST 2017
On Fri, 3 Feb 2017, Wei-keng Liao wrote:
> For running "make check" on Lustre, could you please set the environment
> variable PNETCDF_HINTS to "nc_header_align_size=512;nc_var_align_size=1"
> and run "make check" again? I think it should pass make check. Do let me
> know. These errors only occur for file systems whose striping size is
> larger than 1. So, ext4 is not affected. I am working on a fix for that
> test program. Please note this is a bug in the test program. the PnetCDF
> library itself is intact.
Hi Wei-keng,
Bingo! All tests pass when run on the Lustre filesystem and PNETCDF_HINTS
is set :)
> Thanks for trying various compilers and reporting the problem !
Many thanks for working on pnetcdf and being interested in the problem!
Best,
More information about the parallel-netcdf
