pnetcdf and openmpi 2.0.2?
Mark Dixon m.c.dixon at leeds.ac.uk
Wed Feb 1 07:04:27 CST 2017
I'm having a bit of trouble installing pnetcdf 1.8.1 against openmpi 2.0.2
with the 17.0.1 intel compiler and was wondering if someone could help me,
please?
After successfully building it with:
   MPIF77=`which mpif90` MPIF90=`which mpif90` ./configure --prefix="$prefix" --with-mpi=$MPI_HOME
   make
I'm trying to run tests, but "make check" fails here:
make[2]: Entering directory `/nobackup/parallel-netcdf-1.8.1/test/cdf_format'
./test_inq_format .
*** TESTING C   test_inq_format for inquiring CDF file formats     ------ pass
./cdf_type ./testfile.nc
*** TESTING C   cdf_type for CDF-5 type in CDF-1 and 2             ------ pass
./dim_cdf12 ./testfile.nc
*** TESTING C   dim_cdf12 for defining dim in CDF-1/2 format       ------ Error at line 96: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
Error at line 97: err=NC_ENOTNC (NetCDF: Unknown file format)
Error at line 98: err=NC_EBADID (NetCDF: Not a valid ID)
Error at line 113: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
fail with 4 mismatches
make[2]: *** [testing] Error 2
make[2]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test/cdf_format'
make[1]: *** [check-cdf_format] Error 2
make[1]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test'
make: *** [check] Error 2
If I try a similiar build against intelmpi 2017.1.132 instead of openmpi,
pnetcdf passes all tests.
Am I doing something dumb, please?
Cheers,
