possible bug in prerelease
Jim Edwards
jedwards at ucar.edu
Sun Dec 3 07:55:29 CST 2017
I see you already put up the PR to ROMIO - thanks.
On Fri, Dec 1, 2017 at 10:52 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu
> wrote:
> Hi, Jim
> After taking another look at your assertion error from ad_gpfs_aggrs.c,
> I believe you were hit by a ROMIO bug. I wrote a short test program that
> can cause a similar integer overflow error in ROMIO. The program's URL:
> https://trac.mcs.anl.gov/projects/parallel-netcdf/
> browser/trunk/test/largefile/large_coalesce.c
> Look like the bug has been predicted based on the following comments at
> line 463
> in file ad_gpfs_aggrs.c:
> /* Possibly reconsider if buf_idx's are ok as int's, or should they be
> aints/offsets?
> They are used as memory buffer indices so it seems like the 2G limit
> is in effect */
> After I rebuilt MPICH by changing the data type of buf_idx from int to
> MPI_Aint,
> my test program ran fine. Would you like to create an github issue at
> MPICH repo?
> Wei-keng
> On Dec 1, 2017, at 8:07 PM, Wei-keng Liao wrote:
> > Hi, Jim,
> > Yes, that is a bug. I have developed a fix. Please check out the
> > latest commit from PnetCDF SVN repo and let me know if it works for you.
> > Thanks for reporting.
> > Wei-keng
> > On Dec 1, 2017, at 4:43 PM, Jim Edwards wrote:
> >> I think that I've found a bug in the prerelease in file ncmpio_wait.c
> >> In coalescing blocklengths at line 2095
> >> if (ai - a_last_contig == blocklengths[last_contig_req])
> >> /* user buffer of request j is contiguous from j-1
> >> * we coalesce j to j-1 */
> >> blocklengths[last_contig_req] += blocklengths[j];
> >> It's possible that blocklengths[last_contig_req] + blocklengths[j];
> overflows the integer datatype.
> >> I tried to fix that by avoiding the coalescing:
> >> if ((ai - a_last_contig == blocklengths[last_contig_req]) &&
> >> (blocklengths[last_contig_req] + blocklengths[j] > 0))
> >> but that leads to another overflow problem :
> >> ad_gpfs_aggrs.c:572: ADIOI_GPFS_Calc_my_req: Assertion `curr_idx ==
> (int) curr_idx' failed.
> >> Jim Edwards
> >> CESM Software Engineer
> >> National Center for Atmospheric Research
> >> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20171203/2d707525/attachment.html>
More information about the parallel-netcdf
