Re:Re: Overflow when type cast to 4-byte integer" using nfmpi_get_vara_int
Xueli Huo
201531490002 at mail.bnu.edu.cn
Sun Sep 18 00:00:04 CDT 2016
Hi, Wei-keng,<br/><br/>I am so sorry for making a mistake there. The dimension of var is 3, not 2. <br/>It's OK for nfmpi_get_vara_real_all in pnetcdf-1.6.1. <br/><br/>Thanks so much for your warm-hearted help.<br/><br/>Xueli
At 2016-09-16 23:18:05, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>Hi, Xueli
>Could you print the values of startxy and countxy before calling
>nfmpi_get_vara_real_all? I suspect their values are too large,
>based on the error message you got.
>Wei-keng
>On Sep 14, 2016, at 8:42 PM, Xueli Huo wrote:
>> Hi, all,
>> I am trying to use nfmpi_get_vara_all to get variable values from a CDF-1 file with pnetcdf 1.6.1 and mpi 3.
>> There is a problem that I am not able to solve though I already spent three days trying to figure out what it was on earth.
>> The error message is "Overflow when type cast to 4-byte integer." Here is my code. It is also attached.
>> program trypnetcdf
>> 2
>> 3 use pnetcdf ! Replace nf_ functions with nfmpi_ functions. Huo, 28/08/2016
>> 4 use module_mpp_land, only: io_id, global_nx, global_ny, my_id, mpp_land_sync,MPP_LAND_PAR_INI, mpp_land_init, getLocalXY
>> 5
>> 6 implicit none
>> 7
>> 8 include 'mpif.h'
>> 9
>> 10 integer :: i, j
>> 11 integer :: ix_tmp, jx_tmp
>> 12 integer :: ierr
>> 13 integer :: xstart, xend, ystart, yend
>> 14 real, ALLOCATABLE, DIMENSION(:,:) :: IVGTYP ! vegetation type
>> 15 character(len=256) :: hrldas_constants_file
>> 16
>> 17 call MPP_LAND_INIT()
>> 18 ix_tmp = 1600
>> 19 jx_tmp =1040
>> 20
>> 21 call MPP_LAND_PAR_INI(1,ix_tmp,jx_tmp,1)
>> 22 call getLocalXY(ix_tmp,jx_tmp,xstart,ystart,xend,yend)
>> 23
>> 24
>> 25 hrldas_constants_file="/HOME/gcess_weigong_1/WORKSPACE/CLDASIN/2008010101.LDASIN_DOMAIN0"
>> 26
>> 27 ALLOCATE ( IVGTYP (XSTART:XEND,YSTART:YEND) ) ! vegetation type
>> 28
>> 29 call get_ivgtyp(trim(hrldas_constants_file), xstart, xend, ystart, yend, ivgtyp, "PSFC")
>> 30
>> 31
>> 32 call MPI_COMM_RANK(MPI_COMM_WORLD, my_id, ierr) ! Huo, 29/08/2016
>> 33 if (ierr /= MPI_SUCCESS) stop "MPI_COMM_RANK"
>> 34
>> 35 if(my_id == 0) then
>> 36 print *, 'xstart = ',xstart,'xend = ',xend,'ystart = ',ystart,'yend = ',yend
>> 37 do i = xstart, xend
>> 38 do j = ystart, yend
>> 39 print *, ivgtyp(i,j)
>> 40 end do
>> 41 end do
>> 42 endif
>> 43
>> 44 contains
>> 45
>> 46 subroutine get_ivgtyp(flnm, xstart, xend, ystart, yend, array, varname)
>> 47 implicit none
>> 48 character(len=*), intent(in):: flnm
>> 49 integer , intent(in):: xstart, xend, ystart, yend
>> 50 real, dimension(xstart:xend,ystart:yend), intent(out):: array
>> 51 character(len=*), intent(in):: varname
>> 52 integer(KIND=MPI_OFFSET_KIND),dimension(2) ::startxy, countxy
>> 53 integer :: ierr, ncid, varid
>> 54
>> 55 startxy=(/xstart,ystart/)
>> 56 countxy=(/xend-xstart+1, yend-ystart+1/)
>> 57
>> 58 if(my_id == 0) then
>> 59 print *, xstart, xend, ystart, yend
>> 60 endif
>> 61
>> 62 ierr = nfmpi_open(MPI_COMM_WORLD, trim(flnm), NF_NOWRITE, MPI_INFO_NULL, ncid)
>> 63 if (ierr /= 0) stop "NFMPI_OPEN"
>> 64 ierr = nfmpi_inq_varid(ncid, varname, varid)
>> 65 if (ierr /= 0) stop "NFMPI_INQ_VARID"
>> 66
>> 67 !ierr = nfmpi_get_vara_int_all(ncid, varid, (/xstart,ystart/), (/xend-xstart+1, yend-ystart+1/), array) ! 06/09/2016, Huo.
>> 68 ierr = nfmpi_get_vara_real_all(ncid, varid, startxy, countxy, array) ! 06/09/2016, Huo.
>> 69 print *, ierr
>> 70 if (ierr /= 0) stop "NFMPI_GET_VARA_INT_ALL"
>> 71
>> 72 ierr=nfmpi_close(ncid)
>> 73 if (ierr /= 0) stop "NFMPI_CLOSE"
>> 74
>> 75 end subroutine get_ivgtyp
>> 76
>> 77 end program trypnetcdf
>> Xueli Huo,
>> College of Global Change and Earth System Science
>> Beijing Normal Unviersity
>> Xinjiekouwai Street, No 19
>> Haidian District
>> Beijing, 100875, China
>> <trypnetcdf.F>
More information about the parallel-netcdf
