Problem in variable bounds checking
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Mar 31 13:35:15 CDT 2016
Hi, Greg
This out-of-bound check is unfortunately enforced by netCDF even if count is zero.
There is a comment mentioned at the top of that function. PnetCDF tries to conform
with netCDF on returning error codes, and hence enforces the same check.
A while ago when I revised this part of codes, I tried to skip this check for
zero-length request, but found that will cause many fails for the internal test
programs. Unless netCDF changes its error checking on this, PnetCDF will keep
this the same. Here is a small program I tested against netCDF that can generate
the same error.
#include <stdio.h>
#include <stdlib.h>
#include <netcdf.h>
#define ERR {if(err!=NC_NOERR){printf("Error at line=%d: %s\n", __LINE__, nc_strerror(err));}}
int main(int argc, char** argv) {
    int err, ncid, varid, dimid, buf[10];
    size_t start, count;
    err = nc_create("testfile.nc", NC_WRITE, &ncid); ERR
    err = nc_def_dim(ncid, "dim", 10, &dimid); ERR
    err = nc_def_var(ncid, "var", NC_INT, 1, &dimid, &varid); ERR
    err = nc_enddef(ncid); ERR
    start = 10;
    count = 0;
    err = nc_put_vara_int(ncid, varid, &start, &count, buf); ERR
    err = nc_close(ncid); ERR
    return 0;
Wei-keng
On Mar 31, 2016, at 12:43 PM, Sjaardema, Gregory D wrote:
> The following code is in filetype.c, function `NC_start_count_stride_ck`
>>     for (; i<varp->ndims; i++) {
>>         if (start[i] < 0 || start[i] >= varp->shape[i])
>>             DEBUG_RETURN_ERROR(NC_EINVALCOORDS)
>>         if (varp->shape[i] < 0) DEBUG_RETURN_ERROR(NC_EEDGE)
>>         if (count != NULL) {
>>             if (count[i] < 0) /* no negative count[] */
>>                 DEBUG_RETURN_ERROR(NC_ENEGATIVECNT)
>>             if (stride == NULL) { /* for vara APIs */
>>                 if (count[i] > varp->shape[i] ||
>>                     start[i] + count[i] > varp->shape[i])
>>             else { /* for vars APIs */
>>                 if (count[i] > 0 &&
>>                     start[i] + (count[i]-1) * stride[i] >= varp->shape[i])
>>                 if (stride[i] == 0) DEBUG_RETURN_ERROR(NC_ESTRIDE)
>>         /* else is for var1 APIs */
> There is an issue when the process with the highest rank has zero items to output.  As an example, if I have 4 mpi processes which are each writing the following amount of data:
>  * rank 0: 0 items
>  * rank 1: 2548 items
>  * rank 2: 4352 items
>  * rank 3: 0 items.
> I will define the variable to have a length of 6900 items (0 + 2548 + 4352 + 0).  When I am outputting data to the variable, each rank will call nc_put_vara_longlong with the following start and count values:
>  * rank 0: start = 0, count = 0
>  * rank 1: start = 0, count = 2548
>  * rank 2: start = 2548, count = 4352
>  * rank 3: start = 6900, count = 0.
> In each case, the `start` for rank N is equal to `start` for rank N-1 + `count` for rank N-1.  This all works ok until the highest rank is writing 0 items.  In that case, the `start` value for that rank is equal to the total size of the variable and the check in the code fragment shown above fails since `start[i] == varp->shape[i]`.
> This could be fixed in the application code by checking whether the `count` is zero and if so, then set `start` to 0 also, but I think that is a kluge that should not be required.
> My suggestion is to make the test be:
>   if (start[i] < 0 || (start[i] >= varp->shape[i] && count[i] > 0))
> This is in version 1.7.0.  It also appears in 1.6.1 in the function Nccoordck.
> ..Greg
> "A supercomputer is a device for turning compute-bound problems into I/O-bound problems”
