MPI_Type_create_hindexed errors from PNetCDF 1.7.0
Carl Ponder cponder at nvidia.com
Sat Apr 23 18:25:23 CDT 2016
*On 05/27/2015 05:41 PM, Carl Ponder wrote:*
> Here are some oddities from the "make check" that I ran:
>     ./nf_test       -d .
>     rank 0: MPI error (MPI_File_delete) : MPI_ERR_IO: input/output error
>     *** TESTING F77 ./nf_test for CDF-1
>     ------ pass
*On 05/27/2015 06:41 PM, Wei-keng Liao wrote*
>     Those MPI error messages are expected if you are using OpenMPI or
>     older versions of MPICH. This error happens when trying to delete
>     a non-existing file. A correct MPI implementation should return
>     MPI_ERR_NO_SUCH_FILE, instead of MPI_ERR_IO. This has been fixed
>     in the MPI-IO part of the latest MPICH release. OpenMPI is copying
>     the MPI-IO part of MPICH and has not updated to the latest yet.
>     You can safely ignore those error messages.
With the 1.7.0 release of PNetCDF, I've started getting there errors
from the "make check":
    ./nctst        ./testfile.nc
    [ivb106:6511] *** An error occurred in MPI_Type_create_hindexed
    [ivb106:6511] *** reported by process [46912098861057,46909632806912]
    [ivb106:6511] *** on communicator MPI_COMM_WORLD
    [ivb106:6511] *** MPI_ERR_ARG: invalid argument of some other kind
    [ivb106:6511] *** MPI_ERRORS_ARE_FATAL (processes in this
    communicator will now abort,
    [ivb106:6511] ***    and potentially your MPI job)
    *** TESTING C++ ./nctst for APIs with different netCDF formats
    ------ make[2]: [testing] Error 13 (ignored)
    ./tst_f90      ./testfile.nc
    [ivb106:7079] *** An error occurred in MPI_Type_create_hindexed
    [ivb106:7079] *** reported by process [46912052199425,46909632806912]
    [ivb106:7079] *** on communicator MPI_COMM_WORLD
    [ivb106:7079] *** MPI_ERR_ARG: invalid argument of some other kind
    [ivb106:7079] *** MPI_ERRORS_ARE_FATAL (processes in this
    [ivb106:7079] ***    and potentially your MPI job)
It looks like the 1.6.1 release passed the same:
    ------ pass
    *** TESTING F90 ./tst_f90
    ------ pass
Can you tell me what the issue is here? I'm using OpenMPI 1.10.2 in both
cases.
The error happens when I use the Intel 15.0, GCC 4.8.5 and PGI 16.4
compilers, so I don't believe the compiler is the problem.
                     Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20160423/08b0b665/attachment.html>
