Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Craig Tierney - NOAA Affiliate craig.tierney at noaa.gov
Tue Sep 22 17:30:14 CDT 2015
Wei-keng,
I wasn't able to trigger a problem.  Here is the script I ran around your
test case:
#!/bin/bash --login
module load newdefaults
module load intel
export PATH=/home/admin/software/apps/mvapich2/2.1-intel/bin/:${PATH}
PDIR=/lfs2/jetmgmt/Craig.Tierney/test
if [ ! -d $PDIR/ ]; then
mkdir $PDIR
fi
for s in 1 4; do
if [ ! -d $PDIR/d$s ]; then
mkdir $PDIR/d$s
fi
lfs setstripe -c $s $PDIR/d$s
lfs getstripe $PDIR/d$s
rm -f $PDIR/d$s/bigfile
dd if=/dev/zero of=$PDIR/d$s/bigfile bs=1024k count=1
lfs getstripe $PDIR/d$s/bigfile
echo "Checking d$s"
mpiexec.hydra -np 2 ./check_mpi_striping $PDIR/d$s/bigfile
done
Here are the results:
$ ./doit
/lfs2/jetmgmt/Craig.Tierney/test/d1
stripe_count:   1 stripe_size:    1048576 stripe_offset:  -1
/lfs2/jetmgmt/Craig.Tierney/test/d1/bigfile
lmm_stripe_count:   1
lmm_stripe_size:    1048576
lmm_pattern:        1
lmm_layout_gen:     0
lmm_stripe_offset:  4
obdidx objid objid group
    4      15487258     0xec511a             0
1+0 records in
1+0 records out
1048576 bytes (1.0 MB) copied, 0.00228375 s, 459 MB/s
lmm_stripe_count:   1
lmm_pattern:        1
lmm_layout_gen:     0
lmm_stripe_offset:  7
    7      15421630     0xeb50be             0
Checking d1
Success: striping_unit=1048576 striping_factor=1
/lfs2/jetmgmt/Craig.Tierney/test/d4
stripe_count:   4 stripe_size:    1048576 stripe_offset:  -1
/lfs2/jetmgmt/Craig.Tierney/test/d4/bigfile
lmm_stripe_count:   4
lmm_pattern:        1
lmm_layout_gen:     0
lmm_stripe_offset:  17
   17      15361627     0xea665b             0
   42      15439375     0xeb960f             0
    0      15384104     0xeabe28             0
    2      15522060     0xecd90c             0
1+0 records in
1+0 records out
1048576 bytes (1.0 MB) copied, 0.00210304 s, 499 MB/s
lmm_stripe_count:   4
lmm_pattern:        1
lmm_layout_gen:     0
lmm_stripe_offset:  12
   12      15345301     0xea2695             0
   37      15646009     0xeebd39             0
   41      15695216     0xef7d70             0
   18      15500412     0xec847c             0
Checking d4
Success: striping_unit=1048576 striping_factor=4
Craig
On Tue, Sep 22, 2015 at 3:10 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu
> wrote:
> Hi, Craig
> From these outputs, I think it is most likely due to MPI-IO fails
> to return the same file striping unit and factor values among all
> MPI processes. I guess only root process gets the correct values.
> Attached is a short MPI program to test this theory.
> Could you test it using at least 2 processes on Lustre?
> To compile:
>    mpicc -o check_mpi_striping check_mpi_striping.c
> To run:
>    mpiexec -n 2 check_mpi_striping
> Wei-keng
> On Sep 22, 2015, at 2:34 PM, Craig Tierney - NOAA Affiliate wrote:
> > Wei-keng,
> > Here is the output from my run with PNETCDF_SAFE_MODE=1 on Lustre:
> > [root at Jet:fe8 FLASH-IO]# mpiexec.hydra -env PNETCDF_SAFE_MODE 1 -np 4
> ./flash_benchmark_io /lfs2/jetmgmt/Craig.Tierney/d1//flash_io_test_
> > Warning (inconsistent metadata): variable lrefine's begin (root=1048576,
> local=3072)
> > Warning (inconsistent metadata): variable nodetype's begin
> (root=2097152, local=4608)
> > Warning (inconsistent metadata): variable gid's begin (root=3145728,
> local=6144)
> > Warning (inconsistent metadata): variable coordinates's begin
> (root=4194304, local=25600)
> > Warning (inconsistent metadata): variable blocksize's begin
> (root=5242880, local=33792)
> > Warning (inconsistent metadata): variable bndbox's begin (root=6291456,
> local=41984)
> > Warning (inconsistent metadata): variable dens's begin (root=7340032,
> local=57856)
> > Warning (inconsistent metadata): variable velx's begin (root=18874368,
> local=10641920)
> local=3072)
> local=6144)
> local=41984)
> local=57856)
> local=10641920)
> > Warning (inconsistent metadata): variable vely's begin (root=30408704,
> local=21225984)
> > Warning (inconsistent metadata): variable velz's begin (root=41943040,
> local=31810048)
> > Warning (inconsistent metadata): variable pres's begin (root=53477376,
> local=42394112)
> > Warning (inconsistent metadata): variable ener's begin (root=65011712,
> local=52978176)
> > Warning (inconsistent metadata): variable temp's begin (root=76546048,
> local=63562240)
> > Warning (inconsistent metadata): variable gamc's begin (root=88080384,
> local=74146304)
> > Warning (inconsistent metadata): variable game's begin (root=99614720,
> local=84730368)
> > Warning (inconsistent metadata): variable enuc's begin (root=111149056,
> local=95314432)
> > Warning (inconsistent metadata): variable gpot's begin (root=122683392,
> local=105898496)
> > Warning (inconsistent metadata): variable f1__'s begin (root=134217728,
> local=116482560)
> > Warning (inconsistent metadata): variable f2__'s begin (root=145752064,
> local=127066624)
> > Warning (inconsistent metadata): variable f3__'s begin (root=157286400,
> local=137650688)
> local=3072)
> local=6144)
> local=41984)
> local=57856)
> local=10641920)
> local=21225984)
> local=31810048)
> local=42394112)
> local=52978176)
> local=63562240)
> local=74146304)
> local=84730368)
> local=95314432)
> local=105898496)
> local=116482560)
> local=127066624)
> local=137650688)
> > Warning (inconsistent metadata): variable f4__'s begin (root=168820736,
> local=148234752)
> > Warning (inconsistent metadata): variable f5__'s begin (root=180355072,
> local=158818816)
> > Warning (inconsistent metadata): variable f6__'s begin (root=191889408,
> local=169402880)
> local=21225984)
> local=31810048)
> local=42394112)
> local=52978176)
> local=63562240)
> local=74146304)
> local=84730368)
> local=95314432)
> local=105898496)
> local=116482560)
> local=127066624)
> local=137650688)
> local=148234752)
> local=158818816)
> local=169402880)
> > Warning (inconsistent metadata): variable f7__'s begin (root=203423744,
> local=179986944)
> > Warning (inconsistent metadata): variable f8__'s begin (root=214958080,
> local=190571008)
> > Warning (inconsistent metadata): variable f9__'s begin (root=226492416,
> local=201155072)
> > Warning (inconsistent metadata): variable f10_'s begin (root=238026752,
> local=211739136)
> > Warning (inconsistent metadata): variable f11_'s begin (root=249561088,
> local=222323200)
> > Warning (inconsistent metadata): variable f12_'s begin (root=261095424,
> local=232907264)
> > Warning (inconsistent metadata): variable f13_'s begin (root=272629760,
> local=243491328)
> local=148234752)
> local=158818816)
> local=169402880)
> local=179986944)
> local=190571008)
> local=201155072)
> local=211739136)
> local=222323200)
> local=232907264)
> local=243491328)
> local=179986944)
> local=190571008)
> local=201155072)
> local=211739136)
> local=222323200)
> local=232907264)
> local=243491328)
> >  Here:        -250
> >  Here:        -262
> >  Here:        -262
> >  Here:        -262
> >  nfmpi_enddefFile header is inconsistent among processes
> >  nfmpi_enddef
> >  (Internal error) beginning file offset of this variable is inconsistent
> among p
> >  r
> >  nfmpi_enddef
> among p
> >  r
> >  nfmpi_enddef
> among p
> >  r
> > [cli_1]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
> > [cli_0]: [cli_2]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
> > [cli_3]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
> > aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, -1) - process 0
> > Craig
> > On Mon, Sep 21, 2015 at 1:21 PM, Wei-keng Liao <
> wkliao at eecs.northwestern.edu> wrote:
> > It is strange that the test failed for Lustre.
> > The error message says some variables defined across MPI processes are
> not consistent.
> > Could you run this benchmark with safe mode on? by setting the
> environment variable
> > PNETCDF_SAFE_MODE to 1 before the run. This will print more error
> messages, such as
> > which variables are inconsistent and at what offsets.
> > Wei-keng
> > On Sep 21, 2015, at 1:31 PM, Craig Tierney - NOAA Affiliate wrote:
> > > Rob and Wei-keng,
> > > Thanks for you help on this problem.  Rob - The patch seems to work.
> I had to hand apply it but now the pnetcdf tests (mostly) complete
> successfully.  The FLASH-IO benchmark is failing when Lustre is used.  It
> completes successfully when Panasas is used.  The error code that is
> returned by nfmpi_enddef is -262.   The description for this error is:
> > > #define NC_EMULTIDEFINE_VAR_BEGIN       (-262) /**< inconsistent
> variable file begin offset (internal use) */
> > > [root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io
> /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
> > >  Here:           0
> > >  Here:           0
> > >  Here:           0
> > >  Here:           0
> > >  number of guards      :             4
> > >  number of blocks      :            80
> > >  number of variables   :            24
> > >  checkpoint time       :            12.74  sec
> > >         max header     :             0.88  sec
> > >         max unknown    :            11.83  sec
> > >         max close      :             0.53  sec
> > >         I/O amount     :           242.30  MiB
> > >  plot no corner        :             2.38  sec
> > >         max header     :             0.59  sec
> > >         max unknown    :             1.78  sec
> > >         max close      :             0.22  sec
> > >         I/O amount     :            20.22  MiB
> > >  plot    corner        :             2.52  sec
> > >         max header     :             0.81  sec
> > >         max unknown    :             1.51  sec
> > >         max close      :             0.96  sec
> > >         I/O amount     :            24.25  MiB
> > >  File base name        : /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
> > >    file striping count :             0
> > >    file striping size  :     301346992     bytes
> > >  Total I/O amount      :           286.78  MiB
> > >  nproc    array size      exec (sec)   bandwidth (MiB/s)
> > >     4    16 x  16 x  16     17.64       16.26
> /lfs2/jetmgmt/Craig.Tierney/lfs_flash_io_test_
> > >  Here:        -262
> > >  Here:        -262
> > >  Here:        -262
> > >  nfmpi_enddef
> > >  r
> > >  nfmpi_enddef
> > >  r
> > >  nfmpi_enddef
> > >  r
> > >  Here:           0
> > > [cli_3]: [cli_2]: aborting job:
> > > aborting job:
> > > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > > =   PID 16702 RUNNING AT fe7
> > > =   EXIT CODE: 255
> > > =   CLEANING UP REMAINING PROCESSES
> > > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > > Thanks,
> > > Craig
> > > On Mon, Sep 21, 2015 at 8:30 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> > > On 09/20/2015 03:44 PM, Craig Tierney - NOAA Affiliate wrote:
> > > Wei-keng,
> > > I tried your test code on a different system, and I found it worked
> with
> > > Intel+mvapich2 (2.1rc1).  That system was using Panasas and I was
> > > testing on Lustre.  I then tried Panasas on the original machine
> > > (supports both Panasas and Lustre) and I got the correct behavior.
> > > So the problem somehow related to Lustre.  We are using the 2.5.37.ddn
> > > client.   Unless you have an obvious answer, I will open this with DDN
> > > tomorrow.
> > > Ah, bet I know why this is!
> > > the Lustre driver and (some versions of the) Panasas driver set their
> fs-specific hints by opening the file, setting some ioctls, then continuing
> on without deleting the file.
> > >  In the common case, when we expect the file to show up, no one
> notices or cares, but in MPI_MODE_EXCL or some other restrictive flags, the
> file gets created when we did not expect it to -- and that's part of the
> reason this bug lived on so long.
> > > I fixed this by moving file manipulations out of the hint parsing path
> and into the open path (after we check permissions and flags)
> > > Relevant commit:
> https://trac.mpich.org/projects/mpich/changeset/92f1c69f0de87f9
> > > See more details from Darshan, OpenMPI, and MPICH here:
> > > - https://trac.mpich.org/projects/mpich/ticket/2261
> > > - https://github.com/open-mpi/ompi/issues/158
> http://lists.mcs.anl.gov/pipermail/darshan-users/2015-February/000256.html
> > > ==rob
> > > Thanks,
> > > Craig
> > > On Sun, Sep 20, 2015 at 2:36 PM, Craig Tierney - NOAA Affiliate
> > > <craig.tierney at noaa.gov <mailto:craig.tierney at noaa.gov>> wrote:
> > >     Wei-keng,
> > >     Thanks for the test case.  Here is what I get using a set of
> > >     compilers and MPI stacks.  I was expecting that mvapich2 1.8 and
> 2.1
> > >     would behave differently.
> > >     What versions of MPI do you test internally?
> > >     Craig
> > >     Testing intel+impi
> > >     Currently Loaded Modules:
> > >        1) newdefaults   2) intel/15.0.3.187 <http://15.0.3.187>   3)
> > >     impi/5.1.1.109 <http://5.1.1.109>
> > >     Error at line 22: File does not exist, error stack:
> > >     ADIOI_NFS_OPEN(69): File /lfs3/jetmgmt/Craig.Tierney/
> tooth-fairy.nc
> > >     <http://tooth-fairy.nc> does not exist
> > >     Testing intel+mvapich2 2.1
> > >     mvapich2/2.1
> > >     file was opened: /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
> > >     Testing intel+mvapich2 1.8
> > >     mvapich2/1.8
> > >     Testing pgi+mvapich2 2.1
> > >        1) newdefaults   2) pgi/15.3   3) mvapich2/2.1
> > >     Testing pgi+mvapich2 1.8
> > >        1) newdefaults   2) pgi/15.3   3) mvapich2/1.8
> > >     Craig
> > >     On Sun, Sep 20, 2015 at 1:43 PM, Wei-keng Liao
> > >     <wkliao at eecs.northwestern.edu <mailto:wkliao at eecs.northwestern.edu
> > >     wrote:
> > >         In that case, it is likely mvapich does not perform correctly.
> > >         In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
> > >         PnetCDF calls a MPI_File_open with the open flag set to
> > >         MPI_MODE_RDONLY. See
> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
> > >         Maybe test this with a simple MPI-IO program below.
> > >         It prints error messages like
> > >              Error at line 15: File does not exist, error stack:
> > >              ADIOI_UFS_OPEN(69): File tooth-fairy.nc
> > >         But, no file should be created.
> > >         #include <stdio.h>
> > >         #include <unistd.h> /* unlink() */
> > >         #include <mpi.h>
> > >         int main(int argc, char **argv) {
> > >              int err;
> > >              MPI_File fh;
> > >              MPI_Init(&argc, &argv);
> > >              /* delete "tooth-fairy.nc <http://tooth-fairy.nc>" and
> > >         ignore the error */
> > >              unlink("tooth-fairy.nc <http://tooth-fairy.nc>");
> > >              err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc
> > >         <http://tooth-fairy.nc>", MPI_MODE_RDONLY, MPI_INFO_NULL,
> &fh);
> > >              if (err != MPI_SUCCESS) {
> > >                  int errorStringLen;
> > >                  char errorString[MPI_MAX_ERROR_STRING];
> > >                  MPI_Error_string(err, errorString, &errorStringLen);
> > >                  printf("Error at line %d: %s\n",__LINE__,
> errorString);
> > >              else
> > >                  MPI_File_close(&fh);
> > >              MPI_Finalize();
> > >              return 0;
> > >         Wei-keng
> > >         On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate
> wrote:
> > >          > Wei-keng,
> > >          > I always run distclean before I try to build the code.  The
> > >         first test failing is nc_test.  The problem seems to be in this
> > >         test:
> > >          >    err = ncmpi_open(comm, "tooth-fairy.nc
> > >         <http://tooth-fairy.nc>", NC_NOWRITE, info, &ncid);/* should
> fail */
> > >          >     IF (err == NC_NOERR)
> > >          >         error("ncmpi_open of nonexistent file should have
> > >         failed");
> > >          >     IF (err != NC_ENOENT)
> > >         returned NC_ENOENT");
> > >          >     else {
> > >          >         /* printf("Expected error message complaining:
> \"File
> > >         tooth-fairy.nc <http://tooth-fairy.nc> does not exist\"\n");
> > >          >         nok++;
> > >          > A zero length tooth-fairy.nc <http://tooth-fairy.nc> file
> is
> > >         being created, and I don't think that is supposed to happen.
> > >         That would mean that the mode NC_NOWRITE is not being honored
> by
> > >         MPI_IO.  I will look at this more tomorrow and try to craft a
> > >         short example.
> > >          > Craig
> > >          > On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao
> > >         <mailto:wkliao at eecs.northwestern.edu>> wrote:
> > >          > Hi, Craig
> > >          > Your config.log looks fine to me.
> > >          > Some of your error messages are supposed to report errors of
> > >         opening
> > >          > a non-existing file, but report a different error code,
> > >         meaning the
> > >          > file does exist. I suspect it may be because of residue
> files.
> > >          > Could you do a clean rebuild with the following commands?
> > >          >     % make -s distclean
> > >          >     % ./configure
> --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
> > >          >     % make -s -j8
> > >          >     % make -s check
> > >          > If the problem persists, then it might be because mvapich.
> > >          > Wei-keng
> > > Rob Latham
> > > Mathematics and Computer Science Division
> > > Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150922/31c5bfa5/attachment-0001.html>
