Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Rob Latham robl at mcs.anl.gov
Tue Sep 22 16:44:06 CDT 2015
On 09/22/2015 04:37 PM, Wei-keng Liao wrote:
> Another way to do this is to have root process do the setting, getting, and then
> broadcasting to all processes.
> If you just want the root process to do the setting, then
> you need a barrier to make sure no non-root processes run ahead.
darnit, you're right.
Craig, does this patch fix things for you?
==rob
> Wei-keng
> On Sep 22, 2015, at 4:17 PM, Rob Latham wrote:
>> On 09/22/2015 04:10 PM, Wei-keng Liao wrote:
>>> Hi, Craig
>>>  From these outputs, I think it is most likely due to MPI-IO fails
>>> to return the same file striping unit and factor values among all
>>> MPI processes. I guess only root process gets the correct values.
>>> Attached is a short MPI program to test this theory.
>>> Could you test it using at least 2 processes on Lustre?
>>> To compile:
>>>     mpicc -o check_mpi_striping check_mpi_striping.c
>>> To run:
>>>     mpiexec -n 2 check_mpi_striping
>> what is supposed to happen is that rank 0 sets the striping factor according to the hints all processes requested (it is erroneous to specify different values for an MPI-IO hint on different processes).
>> Rank 0 opens the file and sets the ioctls, then, everyone calls
>> ioctl(fd->fd_sys, LL_IOC_LOV_GETSTRIPE, (void *)lum);
>> It sounds like perhaps I need to learn more about Lustre's rules for when LL_IOC_LOV_SETSTRIPE is visible to all processes.
>> ==rob
>>> Wei-keng
>>> On Sep 22, 2015, at 2:34 PM, Craig Tierney - NOAA Affiliate wrote:
>>>> Wei-keng,
>>>> Here is the output from my run with PNETCDF_SAFE_MODE=1 on Lustre:
>>>> [root at Jet:fe8 FLASH-IO]# mpiexec.hydra -env PNETCDF_SAFE_MODE 1 -np 4 ./flash_benchmark_io /lfs2/jetmgmt/Craig.Tierney/d1//flash_io_test_
>>>> Warning (inconsistent metadata): variable lrefine's begin (root=1048576, local=3072)
>>>> Warning (inconsistent metadata): variable nodetype's begin (root=2097152, local=4608)
>>>> Warning (inconsistent metadata): variable gid's begin (root=3145728, local=6144)
>>>> Warning (inconsistent metadata): variable coordinates's begin (root=4194304, local=25600)
>>>> Warning (inconsistent metadata): variable blocksize's begin (root=5242880, local=33792)
>>>> Warning (inconsistent metadata): variable bndbox's begin (root=6291456, local=41984)
>>>> Warning (inconsistent metadata): variable dens's begin (root=7340032, local=57856)
>>>> Warning (inconsistent metadata): variable velx's begin (root=18874368, local=10641920)
>>>> Warning (inconsistent metadata): variable vely's begin (root=30408704, local=21225984)
>>>> Warning (inconsistent metadata): variable velz's begin (root=41943040, local=31810048)
>>>> Warning (inconsistent metadata): variable pres's begin (root=53477376, local=42394112)
>>>> Warning (inconsistent metadata): variable ener's begin (root=65011712, local=52978176)
>>>> Warning (inconsistent metadata): variable temp's begin (root=76546048, local=63562240)
>>>> Warning (inconsistent metadata): variable gamc's begin (root=88080384, local=74146304)
>>>> Warning (inconsistent metadata): variable game's begin (root=99614720, local=84730368)
>>>> Warning (inconsistent metadata): variable enuc's begin (root=111149056, local=95314432)
>>>> Warning (inconsistent metadata): variable gpot's begin (root=122683392, local=105898496)
>>>> Warning (inconsistent metadata): variable f1__'s begin (root=134217728, local=116482560)
>>>> Warning (inconsistent metadata): variable f2__'s begin (root=145752064, local=127066624)
>>>> Warning (inconsistent metadata): variable f3__'s begin (root=157286400, local=137650688)
>>>> Warning (inconsistent metadata): variable f4__'s begin (root=168820736, local=148234752)
>>>> Warning (inconsistent metadata): variable f5__'s begin (root=180355072, local=158818816)
>>>> Warning (inconsistent metadata): variable f6__'s begin (root=191889408, local=169402880)
>>>> Warning (inconsistent metadata): variable f7__'s begin (root=203423744, local=179986944)
>>>> Warning (inconsistent metadata): variable f8__'s begin (root=214958080, local=190571008)
>>>> Warning (inconsistent metadata): variable f9__'s begin (root=226492416, local=201155072)
>>>> Warning (inconsistent metadata): variable f10_'s begin (root=238026752, local=211739136)
>>>> Warning (inconsistent metadata): variable f11_'s begin (root=249561088, local=222323200)
>>>> Warning (inconsistent metadata): variable f12_'s begin (root=261095424, local=232907264)
>>>> Warning (inconsistent metadata): variable f13_'s begin (root=272629760, local=243491328)
>>>> Here:        -250
>>>> Here:        -262
>>>> Here:        -262
>>>> Here:        -262
>>>> nfmpi_enddefFile header is inconsistent among processes
>>>> nfmpi_enddef
>>>> (Internal error) beginning file offset of this variable is inconsistent among p
>>>> r
>>>> nfmpi_enddef
>>>> r
>>>> nfmpi_enddef
>>>> r
>>>> [cli_1]: aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
>>>> [cli_0]: [cli_2]: aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
>>>> [cli_3]: aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
>>>> aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 0
>>>> Craig
>>>> On Mon, Sep 21, 2015 at 1:21 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>>>> It is strange that the test failed for Lustre.
>>>> The error message says some variables defined across MPI processes are not consistent.
>>>> Could you run this benchmark with safe mode on? by setting the environment variable
>>>> PNETCDF_SAFE_MODE to 1 before the run. This will print more error messages, such as
>>>> which variables are inconsistent and at what offsets.
>>>> Wei-keng
>>>> On Sep 21, 2015, at 1:31 PM, Craig Tierney - NOAA Affiliate wrote:
>>>>> Rob and Wei-keng,
>>>>> Thanks for you help on this problem.  Rob - The patch seems to work.  I had to hand apply it but now the pnetcdf tests (mostly) complete successfully.  The FLASH-IO benchmark is failing when Lustre is used.  It completes successfully when Panasas is used.The error code that is returned by nfmpi_enddef is -262.   The
>>> description for this error is:
>>>>> #define NC_EMULTIDEFINE_VAR_BEGIN       (-262) /**< inconsistent variable file begin offset (internal use) */
>>>>> [root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
>>>>>   Here:           0
>>>>>   Here:           0
>>>>>   Here:           0
>>>>>   Here:           0
>>>>>   number of guards      :             4
>>>>>   number of blocks      :            80
>>>>>   number of variables   :            24
>>>>>   checkpoint time       :            12.74  sec
>>>>>          max header     :             0.88  sec
>>>>>          max unknown    :            11.83  sec
>>>>>          max close      :             0.53  sec
>>>>>          I/O amount     :           242.30  MiB
>>>>>   plot no corner        :             2.38  sec
>>>>>          max header     :             0.59  sec
>>>>>          max unknown    :             1.78  sec
>>>>>          max close      :             0.22  sec
>>>>>          I/O amount     :            20.22  MiB
>>>>>   plot    corner        :             2.52  sec
>>>>>          max header     :             0.81  sec
>>>>>          max unknown    :             1.51  sec
>>>>>          max close      :             0.96  sec
>>>>>          I/O amount     :            24.25  MiB
>>>>>   File base name        : /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
>>>>>     file striping count :             0
>>>>>     file striping size  :     301346992     bytes
>>>>>   Total I/O amount      :           286.78  MiB
>>>>>   nproc    array size      exec (sec)   bandwidth (MiB/s)
>>>>>      4    16 x  16 x  16     17.64       16.26
>>>>> [root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io /lfs2/jetmgmt/Craig.Tierney/lfs_flash_io_test_
>>>>>   Here:        -262
>>>>>   Here:        -262
>>>>>   Here:        -262
>>>>>   nfmpi_enddef
>>>>>   r
>>>>>   nfmpi_enddef
>>>>>   r
>>>>>   nfmpi_enddef
>>>>>   r
>>>>>   Here:           0
>>>>> [cli_3]: [cli_2]: aborting job:
>>>>> aborting job:
>>>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>> =   PID 16702 RUNNING AT fe7
>>>>> =   EXIT CODE: 255
>>>>> =   CLEANING UP REMAINING PROCESSES
>>>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>> Thanks,
>>>>> Craig
>>>>> On Mon, Sep 21, 2015 at 8:30 AM, Rob Latham <robl at mcs.anl.gov> wrote:
>>>>> On 09/20/2015 03:44 PM, Craig Tierney - NOAA Affiliate wrote:
>>>>> Wei-keng,
>>>>> I tried your test code on a different system, and I found it worked with
>>>>> Intel+mvapich2 (2.1rc1).  That system was using Panasas and I was
>>>>> testing on Lustre.  I then tried Panasas on the original machine
>>>>> (supports both Panasas and Lustre) and I got the correct behavior.
>>>>> So the problem somehow related to Lustre.  We are using the 2.5.37.ddn
>>>>> client.   Unless you have an obvious answer, I will open this with DDN
>>>>> tomorrow.
>>>>> Ah, bet I know why this is!
>>>>> the Lustre driver and (some versions of the) Panasas driver set their fs-specific hints by opening the file, setting some ioctls, then continuing on without deleting the file.
>>>>>   In the common case, when we expect the file to show up, no one notices or cares, but in MPI_MODE_EXCL or some other restrictive flags, the file gets created when we did not expect it to -- and that's part of the reason this bug lived on so long.
>>>>> I fixed this by moving file manipulations out of the hint parsing path and into the open path (after we check permissions and flags)
>>>>> Relevant commit:https://trac.mpich.org/projects/mpich/changeset/92f1c69f0de87f9
>>>>> See more details from Darshan, OpenMPI, and MPICH here:
>>>>> -https://trac.mpich.org/projects/mpich/ticket/2261
>>>>> -https://github.com/open-mpi/ompi/issues/158
>>>>> -http://lists.mcs.anl.gov/pipermail/darshan-users/2015-February/000256.html
>>>>> ==rob
>>>>> Thanks,
>>>>> Craig
>>>>> On Sun, Sep 20, 2015 at 2:36 PM, Craig Tierney - NOAA Affiliate
>>>>> <craig.tierney at noaa.gov <mailto:craig.tierney at noaa.gov>> wrote:
>>>>>      Wei-keng,
>>>>>      Thanks for the test case.  Here is what I get using a set of
>>>>>      compilers and MPI stacks.  I was expecting that mvapich2 1.8 and 2.1
>>>>>      would behave differently.
>>>>>      What versions of MPI do you test internally?
>>>>>      Craig
>>>>>      Testing intel+impi
>>>>>      Currently Loaded Modules:
>>>>>         1) newdefaults   2) intel/15.0.3.187 <http://15.0.3.187>   3)
>>>>>      impi/5.1.1.109 <http://5.1.1.109>
>>>>>      Error at line 22: File does not exist, error stack:
>>>>>      ADIOI_NFS_OPEN(69): File /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>>>>>      <http://tooth-fairy.nc> does not exist
>>>>>      Testing intel+mvapich2 2.1
>>>>>      mvapich2/2.1
>>>>>      file was opened: /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>>>>>      Testing intel+mvapich2 1.8
>>>>>      mvapich2/1.8
>>>>>      Testing pgi+mvapich2 2.1
>>>>>         1) newdefaults   2) pgi/15.3   3) mvapich2/2.1
>>>>>      Testing pgi+mvapich2 1.8
>>>>>         1) newdefaults   2) pgi/15.3   3) mvapich2/1.8
>>>>>      Craig
>>>>>      On Sun, Sep 20, 2015 at 1:43 PM, Wei-keng Liao
>>>>>      <wkliao at eecs.northwestern.edu <mailto:wkliao at eecs.northwestern.edu>>
>>>>>      wrote:
>>>>>          In that case, it is likely mvapich does not perform correctly.
>>>>>          In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
>>>>>          PnetCDF calls a MPI_File_open with the open flag set to
>>>>>          MPI_MODE_RDONLY. See
>>>>> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
>>>>>          Maybe test this with a simple MPI-IO program below.
>>>>>          It prints error messages like
>>>>>               Error at line 15: File does not exist, error stack:
>>>>>               ADIOI_UFS_OPEN(69): File tooth-fairy.nc
>>>>>          But, no file should be created.
>>>>>          #include <stdio.h>
>>>>>          #include <unistd.h> /* unlink() */
>>>>>          #include <mpi.h>
>>>>>          int main(int argc, char **argv) {
>>>>>               int err;
>>>>>               MPI_File fh;
>>>>>               MPI_Init(&argc, &argv);
>>>>>               /* delete "tooth-fairy.nc <http://tooth-fairy.nc>" and
>>>>>          ignore the error */
>>>>>               unlink("tooth-fairy.nc <http://tooth-fairy.nc>");
>>>>>               err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc
>>>>>          <http://tooth-fairy.nc>", MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
>>>>>               if (err != MPI_SUCCESS) {
>>>>>                   int errorStringLen;
>>>>>                   char errorString[MPI_MAX_ERROR_STRING];
>>>>>                   MPI_Error_string(err, errorString, &errorStringLen);
>>>>>                   printf("Error at line %d: %s\n",__LINE__, errorString);
>>>>>               else
>>>>>                   MPI_File_close(&fh);
>>>>>               MPI_Finalize();
>>>>>               return 0;
>>>>>          Wei-keng
>>>>>          On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate wrote:
>>>>>           > Wei-keng,
>>>>>           > I always run distclean before I try to build the code.  The
>>>>>          first test failing is nc_test.  The problem seems to be in this
>>>>>          test:
>>>>>           >    err = ncmpi_open(comm, "tooth-fairy.nc
>>>>>          <http://tooth-fairy.nc>", NC_NOWRITE, info, &ncid);/* should fail */
>>>>>           >     IF (err == NC_NOERR)
>>>>>           >         error("ncmpi_open of nonexistent file should have
>>>>>          failed");
>>>>>           >     IF (err != NC_ENOENT)
>>>>>          returned NC_ENOENT");
>>>>>           >     else {
>>>>>           >         /* printf("Expected error message complaining: \"File
>>>>>          tooth-fairy.nc <http://tooth-fairy.nc> does not exist\"\n"); */
>>>>>           >         nok++;
>>>>>           > A zero length tooth-fairy.nc <http://tooth-fairy.nc> file is
>>>>>          being created, and I don't think that is supposed to happen.
>>>>>          That would mean that the mode NC_NOWRITE is not being honored by
>>>>>          MPI_IO.  I will look at this more tomorrow and try to craft a
>>>>>          short example.
>>>>>           > Craig
>>>>>           > On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao
>>>>>          <mailto:wkliao at eecs.northwestern.edu>> wrote:
>>>>>           > Hi, Craig
>>>>>           > Your config.log looks fine to me.
>>>>>           > Some of your error messages are supposed to report errors of
>>>>>          opening
>>>>>           > a non-existing file, but report a different error code,
>>>>>          meaning the
>>>>>           > file does exist. I suspect it may be because of residue files.
>>>>>           > Could you do a clean rebuild with the following commands?
>>>>>           >     % make -s distclean
>>>>>           >     % ./configure --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
>>>>>           >     % make -s -j8
>>>>>           >     % make -s check
>>>>>           > If the problem persists, then it might be because mvapich.
>>>>>           > Wei-keng
>>>>> Rob Latham
>>>>> Mathematics and Computer Science Division
>>>>> Argonne National Lab, IL USA
>> Rob Latham
Rob Latham
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150922/53c1c740/attachment-0001.bin>
