Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Sun Sep 20 17:17:05 CDT 2015
For loaded module 3) impi/5.1.1.109
> ADIOI_NFS_OPEN(69): File /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc does not exist
This error message says your MPI library thinks /lfs3/jetmgmt/Craig.Tierney is an NFS, not Lustre.
Either /lfs3 is not a Lustre or the configuration of your MPI compiler is not made right.
Please check your MPI configure setting to see if lustre appears in --with-file-system option.
For loaded module 3) mvapich2/*, what exactly the error messages are?
Does it start with ADIOI_LUSTRE_OPEN?
Wei-keng
On Sep 20, 2015, at 3:44 PM, Craig Tierney - NOAA Affiliate wrote:
> Wei-keng,
> I tried your test code on a different system, and I found it worked with Intel+mvapich2 (2.1rc1). That system was using Panasas and I was testing on Lustre. I then tried Panasas on the original machine (supports both Panasas and Lustre) and I got the correct behavior.
> So the problem somehow related to Lustre. We are using the 2.5.37.ddn client. Unless you have an obvious answer, I will open this with DDN tomorrow.
> Thanks,
> Craig
> On Sun, Sep 20, 2015 at 2:36 PM, Craig Tierney - NOAA Affiliate <craig.tierney at noaa.gov> wrote:
> Wei-keng,
> Thanks for the test case. Here is what I get using a set of compilers and MPI stacks. I was expecting that mvapich2 1.8 and 2.1 would behave differently.
> What versions of MPI do you test internally?
> Craig
> Testing intel+impi
> Currently Loaded Modules:
> 1) newdefaults 2) intel/15.0.3.187 3) impi/5.1.1.109
> Error at line 22: File does not exist, error stack:
> Testing intel+mvapich2 2.1
> 1) newdefaults 2) intel/15.0.3.187 3) mvapich2/2.1
> file was opened: /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
> Testing intel+mvapich2 1.8
> 1) newdefaults 2) intel/15.0.3.187 3) mvapich2/1.8
> Testing pgi+mvapich2 2.1
> 1) newdefaults 2) pgi/15.3 3) mvapich2/2.1
> Testing pgi+mvapich2 1.8
> 1) newdefaults 2) pgi/15.3 3) mvapich2/1.8
> Craig
> On Sun, Sep 20, 2015 at 1:43 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> In that case, it is likely mvapich does not perform correctly.
> In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
> PnetCDF calls a MPI_File_open with the open flag set to MPI_MODE_RDONLY. See
> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
> Maybe test this with a simple MPI-IO program below.
> It prints error messages like
> Error at line 15: File does not exist, error stack:
> ADIOI_UFS_OPEN(69): File tooth-fairy.nc does not exist
> But, no file should be created.
> #include <stdio.h>
> #include <unistd.h> /* unlink() */
> #include <mpi.h>
> int main(int argc, char **argv) {
> int err;
> MPI_File fh;
> MPI_Init(&argc, &argv);
> /* delete "tooth-fairy.nc" and ignore the error */
> unlink("tooth-fairy.nc");
> err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc", MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
> if (err != MPI_SUCCESS) {
> int errorStringLen;
> char errorString[MPI_MAX_ERROR_STRING];
> MPI_Error_string(err, errorString, &errorStringLen);
> printf("Error at line %d: %s\n",__LINE__, errorString);
> else
> MPI_File_close(&fh);
> MPI_Finalize();
> return 0;
> Wei-keng
> On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate wrote:
> > Wei-keng,
> > I always run distclean before I try to build the code. The first test failing is nc_test. The problem seems to be in this test:
> > err = ncmpi_open(comm, "tooth-fairy.nc", NC_NOWRITE, info, &ncid);/* should fail */
> > IF (err == NC_NOERR)
> > error("ncmpi_open of nonexistent file should have failed");
> > IF (err != NC_ENOENT)
> > error("ncmpi_open of nonexistent file should have returned NC_ENOENT");
> > else {
> > /* printf("Expected error message complaining: \"File tooth-fairy.nc does not exist\"\n"); */
> > nok++;
> > A zero length tooth-fairy.nc file is being created, and I don't think that is supposed to happen. That would mean that the mode NC_NOWRITE is not being honored by MPI_IO. I will look at this more tomorrow and try to craft a short example.
> > Craig
> > On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> > Hi, Craig
> > Your config.log looks fine to me.
> > Some of your error messages are supposed to report errors of opening
> > a non-existing file, but report a different error code, meaning the
> > file does exist. I suspect it may be because of residue files.
> > Could you do a clean rebuild with the following commands?
> > % make -s distclean
> > % ./configure --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
> > % make -s -j8
> > % make -s check
> > If the problem persists, then it might be because mvapich.
> > Wei-keng
More information about the parallel-netcdf
