parallel NetCDF: One or more variable sizes violate format constraints
Jim Edwards
jedwards at ucar.edu
Mon Nov 9 21:24:09 CST 2015
The netcdf-3 classic file is incorrect and probably corrupt - 16GB exceeds
the variable size constraints of that format. You can use CDF5 as output
by pnetcdf to write the file and then read it again with pnetcdf but netcdf
doesn't support the CDF5 standard until version 4.4.
On Mon, Nov 9, 2015 at 7:47 PM, Felicity Graham <f.s.graham at utas.edu.au>
wrote:
> Hello,
> I’d like to use parallel netcdf in C to read the only variable from a 16GB
> netcdf file and perform some operations.
> The file format is classic, and was created with netcdf 3.6.3. I’m
> using openmpi 1.6.3 and pnetcdf 1.4.1.
> I’ve tested on a separate netcdf-4 formatted file, and the reading works
> fine, but on the classic file, I get the error NetCDF: One or more
> variable sizes violate format constraints when I try to open the file
> (ncmpi_open).
> A stripped down version of the C code is below.
> Your help is much appreciated.
> Cheers,
> Felicity
> #include <stdio.h>
> #include <mpi.h>
> #include <pnetcdf.h>
> #define FILE_NAME “<path_to_file>/hf_topog.nc"
> #define VAR_NAME "hf_topog"
> #define CHECK_ERR {\
> if (err!=NC_NOERR) {\
> printf("Error at line=%d: %s\n", __LINE__, ncmpi_strerror(err));\
> goto fn_exit;\
> int main(int argc, char **argv)
> int err, varid, ncid;
> float * topog_in;
> MPI_Init(&argc,&argv);
> err = ncmpi_open(MPI_COMM_WORLD, FILE_NAME, NC_NOWRITE, MPI_INFO_NULL,
> &ncid);
> CHECK_ERR;
> err = ncmpi_close(ncid);
> CHECK_ERR;
> fn_exit:
> MPI_Finalize();
> return 0;
> University of Tasmania Electronic Communications Policy (December, 2014).
> This email is confidential, and is for the intended recipient only.
> Access, disclosure, copying, distribution, or reliance on any of it by
> anyone outside the intended recipient organisation is prohibited and may be
> a criminal offence. Please delete if obtained in error and email
> confirmation to the sender. The views expressed in this email are not
> necessarily the views of the University of Tasmania, unless clearly
> intended otherwise.
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20151109/69ef3df5/attachment.html>
More information about the parallel-netcdf
