mpi error from ncmpi_end_indep_data
Jim Edwards jedwards at ucar.edu
Tue Dec 30 13:12:04 CST 2014
Okay great - thank you!
On Tue, Dec 30, 2014 at 12:11 PM, Wei-keng Liao <
wkliao at eecs.northwestern.edu> wrote:
> Hi, Jim
> After I move the call to ncmpi_wait() to after ncmpi_end_indep_data()
> I can reproduce the error.
> The problem has been fixed in the latest revision of PnetCDF.
> Wei-keng
> On Dec 30, 2014, at 12:13 PM, Wei-keng Liao wrote:
> > Hi, Jim
> > I was not able to reproduce the error. Could you try the following
> program?
> > Also, could you add an error checking for the ncmpi APIs before
> ncmpi_end_indep_data.
> > I wonder if there is an error returned from one of those APIs.
> > #include <stdio.h>
> > #include <stdlib.h>
> > #include <mpi.h>
> > #include <pnetcdf.h>
> > #define NY 4
> > #define NX 10
> > #define NDIMS 2
> > #define ERR \
> >    if (err != NC_NOERR) { \
> >        printf("Error at line=%d: %s\n", __LINE__, ncmpi_strerror(err)); \
> > int main(int argc, char** argv)
> >    int rank, nprocs, err;
> >    int ncid, varid, dimid[2], req, st;
> >    MPI_Offset start[2], count[2], stride[2];
> >    unsigned char buffer[NY][NX];
> >    MPI_Init(&argc, &argv);
> >    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> >    MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
> >    err = ncmpi_create(MPI_COMM_WORLD, "testfile.nc",
> NC_CLOBBER|NC_64BIT_DATA,
> >                       MPI_INFO_NULL, &ncid);
> >    ERR
> >    err = ncmpi_def_dim(ncid, "Y", NY,        &dimid[0]); ERR
> >    err = ncmpi_def_dim(ncid, "X", NX*nprocs, &dimid[1]); ERR
> >    err = ncmpi_def_var(ncid, "var", NC_UBYTE, NDIMS, dimid, &varid); ERR
> >    err = ncmpi_enddef(ncid); ERR
> >     start[0] = 0;     start[1] = NX*rank;
> >     count[0] = NY/2;  count[1] = NX/2;
> >    stride[0] = 2;    stride[1] = 2;
> >    err = ncmpi_buffer_attach(ncid, NY*NX); ERR
> >    err = ncmpi_begin_indep_data(ncid); ERR
> >    err = ncmpi_bput_vars_uchar(ncid, varid, start, count, stride,
> >                                &buffer[0][0], &req);
> >    ERR
> >    err = ncmpi_wait(ncid, 1, &req, &st); ERR
> >    err = ncmpi_end_indep_data(ncid); ERR
> >    err = ncmpi_buffer_detach(ncid); ERR
> >    err = ncmpi_close(ncid); ERR
> >    MPI_Finalize();
> >    return 0;
> > Wei-keng
> > On Dec 30, 2014, at 10:31 AM, Jim Edwards wrote:
> >> Hi Wei-keng,
> >> I have a code block that looks like:
> >>      ncmpi_begin_indep_data(file->fh);
> >>      usage = 0;
> >>      if(ios->io_rank==file->indep_rank){
> >> ierr = ncmpi_bput_vars_uchar(file->fh, varid, start, count, stride, op,
> &request);;
> >> pio_push_request(file, request);
> >> ierr = ncmpi_inq_buffer_usage(ncid, &usage);
> >> //   printf("%s %d %d\n",__FILE__,__LINE__,usage);
> >>      ncmpi_end_indep_data(file->fh);
> >> It's generating an error message on the ncmpi_end_indep_data call:
> >> MPI_FILE_WRITE_AT(83): File does not exist
> >> Regardless of the error message the write seems to work fine, any idea
> what's causing this?
> >> I'm using pnetcdf svn revision 1920 with intel 15 compiler and mpich.
> >> - Jim
> >> Jim Edwards
> >> CESM Software Engineer
> >> National Center for Atmospheric Research
> >> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20141230/3b5e6f75/attachment.html>
