pnetcdf nfmpi_put_vara_real_all problem
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Thu Sep 19 08:34:54 CDT 2013
David,
This is a different error from the previous one you reported.
This error most likely is caused by the compile and link with
wrong MPI or PnetCDF libraries, as nfmpi_create is the first
PnetCDF call in the test program.
I google the error message and it seems like you compiled with
a wrong MPI header file, maybe implying the PnetCDF library was
built with a different MPI compiler from the one you used to
compile this test program.
Could you show us how you compile the program?
Also, what version of PnetCDF is used to compile?
Wei-keng
On Sep 19, 2013, at 7:35 AM, Wong, David wrote:
> Hi Wei-keng,
>     It failed at the following step:
>         err = nfmpi_create(MPI_COMM_WORLD, filename, NF_CLOBBER,
>     +                       MPI_INFO_NULL, ncid)
> with the following error message (from one of the processor):
> Rank 1 [Thu Sep 19 04:27:50 2013] [c5-0c1s4n3] Fatal error in MPI_Comm_test_inter: Invalid communicator, error stack:
> MPI_Comm_test_inter(110): MPI_Comm_test_inter(comm=0x84000002, flag=0x7fffffff8f90) failed
> MPI_Comm_test_inter(83).: Invalid communicator
> Rank 2 [Thu Sep 19 04:27:50 2013] [c5-0c1s4n3] Fatal error in MPI_Comm_test_inter: Invalid communicator, error stack:
> Rank 3 [Thu Sep 19 04:27:50 2013] [c5-0c1s4n3] Fatal error in MPI_Comm_test_inter: Invalid communicator, error stack:
> Rank 0 [Thu Sep 19 04:27:50 2013] [c5-0c1s4n3] Fatal error in MPI_Comm_test_inter: Invalid communicator, error stack:
> MPI_Comm_test_inter(110): MPI_Comm_test_inter(comm=0x84000004, flag=0x7fffffff8f90) failed
> forrtl: error (76): Abort trap signal
> Image              PC                Routine            Line        Source
> libc.so.6          00002AAAAB92CB35  Unknown               Unknown  Unknown
> libc.so.6          00002AAAAB92E111  Unknown               Unknown  Unknown
> epa.x              0000000000435E42  Unknown               Unknown  Unknown
> epa.x              000000000042B160  Unknown               Unknown  Unknown
> epa.x              000000000042B30D  Unknown               Unknown  Unknown
> libmpich_intel.so  00002AAAAC248B83  Unknown               Unknown  Unknown
> epa.x              0000000000523C3E  Unknown               Unknown  Unknown
> epa.x              000000000051E508  Unknown               Unknown  Unknown
> epa.x              000000000051DBC5  Unknown               Unknown  Unknown
> epa.x              00000000004245EF  MAIN__                     33  epa.F
> epa.x              000000000042454C  Unknown               Unknown  Unknown
> libc.so.6          00002AAAAB918C16  Unknown               Unknown  Unknown
> epa.x              000000000042444D  Unknown               Unknown  Unknown
>    Regarding to Rob's suggestion, I am using aprun or mpirun to launch the executable so I don't know how to invoke valgrind at this time.
> Cheers,
> David
> David C. Wong Ph.D.
> Atmospheric Modeling and Analysis Division
> National Exposure Research Laboratory
> US Environmental Protection Agency
> Mail Drop E243-03
> 109 T. W. Alexander Dr.
> Research Triangle Park, NC 27711
> 919-541-3400 919-541-1379 (fax)
> From: Wei-keng Liao <wkliao at ece.northwestern.edu>
> Sent: Wednesday, September 18, 2013 7:13 PM
> To: Wong, David
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: pnetcdf nfmpi_put_vara_real_all problem
> Hi, David,
> Could you please try the attached program and let us know if it
> generates the same error? It is written based on the information
> you provided.
More information about the parallel-netcdf
