pnetcdf nfmpi_put_vara_real_all problem
Wei-keng Liao wkliao at ece.northwestern.edu
Wed Sep 18 18:13:48 CDT 2013
Hi, David,
Could you please try the attached program and let us know if it
generates the same error? It is written based on the information
you provided.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130918/5278f2cf/attachment.obj>
Wei-keng
On Sep 18, 2013, at 12:46 PM, Wong, David wrote:
> Hi Wei-keng,
>     start and count have been declared as:
>          NFMPI_OFFSET :: start(4), count(4)
> I have tested in a smaller version of code and it worked. After I put it in our numerical model and it crashed. Any other thought? Please advise.
> Cheers,
> David
> From: Wei-keng Liao <wkliao at ece.northwestern.edu>
> Sent: Wednesday, September 18, 2013 1:01 PM
> To: Wong, David
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: pnetcdf nfmpi_put_vara_real_all problem
> Hi, David,
> Could you send us the code fragment or the program that can reproduce the error?
> Just a reminder. The datatype of start and count must be integer*8.
> Similarly, use integer*8 to define dimensions.
> If you have done that already, there must be something else.
> Wei-keng
> On Sep 18, 2013, at 11:09 AM, David Wong wrote:
>> Hi,
>>   I am able to create a file:
>> netcdf pCTM_CONC_1 {
>> dimensions:
>>        cols = 423 ;
>>        rows = 594 ;
>>        lays = 14 ;
>>        time = UNLIMITED ; // (0 currently)
>>        vars = 142 ;
>> variables:
>>        float NO2(time, lays, rows, cols) ;
>>        float NO(time, lays, rows, cols) ;
>>        float O(time, lays, rows, cols) ;
>> The code crashed with a segmentation fault (indicated the following line by traceback option):
>>        stat = nfmpi_put_vara_real_all (loc_pos%fileid, loc_pos%var_id(v), start, count, loc_data)
>> The argument for this call in one of the processor is:
>> loc_pos%fileid = 0
>> loc_pos%var_id(v) = 1
>> start =   1    1    1    1
>> count = 423   50   14    1
>> loc_data (size) = 423     50     14
>> I wonder what is the problem. Please advise.
>> Cheers,
>> David
