[netCDF #KLB-596506]: apparent bug in netcdf-4.2
Jim Edwards
jedwards at ucar.edu
Mon Mar 4 18:49:37 CST 2013
Hi Russ,
That turns out to have been the problem. The original file was created
with pnetcdf.
Jim
On Mon, Mar 4, 2013 at 3:12 PM, Jim Edwards <jedwards at ucar.edu> wrote:
> Russ,
> We think that the original file may have been written with pnetcdf. We
> are going to try to recreate the file with netcdf and again with pnetcdf
> and see if that explains the issue.
> Jim
> On Mon, Mar 4, 2013 at 2:31 PM, Samuel Levis <slevis at ucar.edu> wrote:
>> Not exactly. I tried 2-degree to 2-degree, 2-degree to 0.5, 2-degree to
>> 0.25, and others. All cases worked except the ones with the 0.5-degree file
>> as output.
>> I also tried 0.5-degree to 0.5-degree (mapping the file into itself) and
>> that failed. When I say failed, I mean that the output file ends up with
>> junk in it.
>> Sam
>> On 03/04/2013 02:26 PM, Jim Edwards wrote:
>> Hi Russ,
>> Another piece of information. This program interpolates data from a
>> file of one resolution (2 degree in this case) to another. When the output
>> file is low resolution, 1/2 degree or lower, the output file looks fine, no
>> corruption that we can detect. It's only when the output file is higher
>> resolution (1/4 degree) that this problem comes about.
>> Jim
>> On Mon, Mar 4, 2013 at 2:04 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>>> Hi Russ,
>>> It looks like that file was originally created on bluefire on 11/21/11,
>>> I don't have any information about which netcdf library was used, but I
>>> think that some adjustment may have been made inside netcdf for performance
>>> on gpfs filesystems.
>>> But doesn't your own
>>> int nc__enddef(int ncid, size_t h_minfree, size_t v_align,
>>> size_t v_minfree, size_t r_align);
>>> allow for changing this alignment? I don't know that that was done for
>>> this file, but it would seem to suggest that there is no assumption being
>>> violated about these alignments. Or that one part of netcdf is assuming
>>> something which another part is not.
>>> On Mon, Mar 4, 2013 at 12:53 PM, Unidata netCDF Support <
>>> support-netcdf at unidata.ucar.edu> wrote:
>>>> Hi Jim,
>>>> I'm curious how the original file you provided was created and perhaps
>>>> modified. It has a peculiar alignment characteristic that I haven't
>>>> seen before, and if there are more netCDF files being created the same
>>>> way, we may nned to adapt.
>>>> Could you tell me the history of the file, what file system it was
>>>> written on, and whether the netCDF library with which it was written
>>>> was modified in any way?
>>>> The file has this characteristic, which would indicate a non-Posix
>>>> file system: it is using 512-byte alignment of data values rather than
>>>> the 4-byte alignment assumed by netCDF. So, for example, the data
>>>> block for fixed-size variables begins with 9 scalar integers that
>>>> should take 4 bytes each. The offsets computed for these values from
>>>> the beginning of the fixed-size data block are 0, 4, 8, 12, 16, 20,
>>>> 24, 28, 32, so there is no padding or wasted space. The offsets from
>>>> the beginning of the fixed-size data block that are actually stored in
>>>> the
>>>> header for these variables are 0, 512, 1024, ... , 4096. If the file
>>>> system used to write the data originally could not write data on
>>>> 4-byte boundaries, I think that violates the assumption of netCDF and
>>>> POSIX I/O. Nevertheless, if the nc_endef() call pays attention to the
>>>> file offsets for each variable that are stored in the header (as the
>>>> netCDF library does when reading the file), rather than computing them
>>>> from assuming 4-byte alignment, perhaps this file can be modified
>>>> correctly.
>>>> The function where we might be able to adapt to this is
>>>> nc3internal.c:NC_begins(), which is called from
>>>> nc3internal.c:NC_enddef(). In any case it's a netCDF bug to write
>>>> something that can't be later read correctly, so if our unmodified
>>>> library wrote that file and we can't adapt to it, then it was a bug
>>>> to not emit an error message for trying to create a file on the original
>>>> non-POSIX file system. Also, the data seems to all be there in the
>>>> "corrupted" file, which can be fixed by just restoring the variable
>>>> offsets in the file header to the peculiar values in the original ...
>>>> --Russ
>>>> Russ Rew UCAR Unidata Program
>>>> russ at unidata.ucar.edu http://www.unidata.ucar.edu
>>>> Ticket Details
>>>> Ticket ID: KLB-596506
>>>> Department: Support netCDF
>>>> Priority: Normal
>>>> Status: Closed
>>> Jim Edwards
>>> CESM Software Engineering Group
>>> National Center for Atmospheric Research
>>> Boulder, CO
>>> 303-497-1842
>> Jim Edwards
>> Boulder, CO
>> 303-497-1842
>> Samuel Levis - slevis at ucar.edu
>> PO Box 3000, Boulder CO 80307-3000 <- use for mail
>> 3090 Center Green Dr., Boulder CO 80301 <- vs. shipping
>> tel 303 497-1627; fax -1348; skype: samuellevis2http://www.cgd.ucar.edu/tss
>> Terrestrial Sciences Section in the
>> Climate & Global Dynamics Division
> Jim Edwards
> Boulder, CO
> 303-497-1842
Jim Edwards
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130304/011b1b90/attachment.html>
More information about the parallel-netcdf
