Problem in compiling example programs
Wei-keng Liao wkliao at ece.northwestern.edu
Sun Jun 30 18:55:35 CDT 2013
Thanks, Rajeev. The fix has been added to the SVN repo.
Hi, Lyndon,
Thanks for giving our latest SVN a try. (File flex_f.f90 is
yet to be official released.) Your testing helps us improve
the software for next release. If you find any further
problem or questions, please let us know.
Wei-keng
On Jun 30, 2013, at 2:09 AM, Rajeev Thakur wrote:
> It should be MPI_INTEGER instead of MPI_INT in Fortran.
> On Jun 30, 2013, at 1:45 AM, Lyndon Lu wrote:
>> Hi,
>>    When running make under sub-dir examples, one of fortran program cannot be compiled successfully ( see below) and other programs seem to be fine.
>> /opt/openmpi/1.4.3/bin/mpif90 -c -g -I../src/lib  -I../src/libf  flex_f.f90
>> flex_f.f90(117): error #6404: This name does not have a type, and must have an explicit type.   [MPI_INT]
>>               MPI_INT, subarray, err)
>> flex_f.f90(115): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MPI_TYPE_CREATE_SUBARRAY]
>>          call MPI_Type_create_subarray(2, array_of_sizes, &
>> compilation aborted for flex_f.f90 (code 1)
>> make: *** [flex_f.o] Error 1
>>     Does anyone know what's wrong with this program flex_f.90? I am using pnetcdf 1.3.1/netcdf 4.3.0/hdf5 1.8.11.
>>      In addition, could someone tell me what's advantage of using ncmpidump over ncdump? It seems that there is not an option in the command line to set the number of cpus for ncmpidump.
>>      Thanks.
>> Cheers,
>> Lyndon
