possible bug in pnetcdf: cdf5 issue
Jim Edwards
jedwards at ucar.edu
Sun Feb 17 12:43:17 CST 2013
In my larger program I am getting an error:
PMPI_Type_create_struct(139): Invalid value for blocklen, must be
non-negative but is -1715470336
I see a note about this in nonblocking.c:
for (j=0; j<reqs[i].varp->ndims; j++)
blocklens[i] *= reqs[i].count[j];
/* Warning! blocklens[i] might overflow */
But I tried to distile this into a small testcase and I'm getting a
different error, I've attached the test program anyway because I can't spot
any error there and think it must be in pnetcdf. Also it seems like
instead of
calling mpi_type_create_struct you should be calling mpi_type_subarray
which will avoid the problem of blocklens overflowing.
This test program is written for 8 mpi tasks, but it uses a lot of memory
so you may need more than one node to run it.
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130217/88c78641/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130217/88c78641/attachment.obj>
More information about the parallel-netcdf
