Assertion `ncp->head != ((void *)0)' failed.
Liu, Jaln
jaln.liu at ttu.edu
Wed Feb 13 13:43:30 CST 2013
Hi Dr. Liao,
Thank you. Other ncmpi call works fine, like ncmpi_get_vara_float and ncmpi_get_vara_float_all,
>Also, I am seeing this line in your codes:
> nb_temp_in[rank]=calloc(varasize,sizeof(float));
Yes, it should be `nb_temp'.
I wonder can we use ncmpi_iget_vara() on the same variable but different starts&lengths. From the sample program, it is used for multiple variables.
Jialin
From: parallel-netcdf-bounces at lists.mcs.anl.gov [parallel-netcdf-bounces at lists.mcs.anl.gov] on behalf of Wei-keng Liao [wkliao at ece.northwestern.edu]
Sent: Wednesday, February 13, 2013 1:28 PM
To: parallel-netcdf at lists.mcs.anl.gov
Subject: Re: Assertion `ncp->head != ((void *)0)' failed.
Hi, Jialin,
I suspect it is because the call to ncmpi_iget_vara() failed.
Please check the return values of all your ncmpi_ calls.
It may tell you if you got an error before you would like to continue.
But you are using nb_temp[rank] in ncmpi_iget_vara()
Wei-keng
On Feb 13, 2013, at 12:13 PM, Liu, Jaln wrote:
> Hi,
> When I run the codes below, I got an error " Assertion `ncp->head != ((void *)0)' failed."
> (I looked into the source codes, I saw a operation of checking Id, seems each request should be checked and matched with the file handle? I don't know the reason)
> float ** nb_temp;
> nb_temp=malloc(nprocs*sizeof(float *));
> int * request=calloc(nprocs, sizeof(int));
> int * status=calloc(nprocs,sizeof(int));
> mpi_start[1]=rank*5;//starts on other dimensions are specified to 0.
> int varasize=100*10*NLAT*NLON;
> ncmpi_iget_vara(ncid, temp_varid, mpi_start,mpi_count,nb_temp[rank],varasize,MPI_FLOAT,&(request[rank]);
> ncmpi_wait_all(ncid, nprocs, request, status);
> A detailed return is in the attachment,
> Can you please tell me what's wrong with the codes?
> I appreciate it.
> Jialin
> <56034.e>
More information about the parallel-netcdf
