pnetcdf 1.2.0 create file issue
Jim Edwards jedwards at ucar.edu
Thu May 10 16:28:57 CDT 2012
This occurs on the ncsa machine bluewaters.   I am using pnetcdf1.2.0 and
pgi 11.10.0
The issue is that calling nfmpi_createfile would sometimes result in an
error:
MPI_File_open : Other I/O error , error stack:
(unknown)(): Other I/O error
126: MPI_File_open : Other I/O error , error stack:
  Error on create :           502          -32
The error appears to be intermittent and I could not get it to occur at all
on a small number of tasks (160) but it occurs with high frequency when
using a larger number of tasks (>=1600).    I traced the problem to the use
of nf_clobber in the mode argument, removing the nf_clobber seems to have
solved the problem and I think that create implies clobber anyway doesn't
it?    Can someone who knows what is going on under the covers enlighten me
with some understanding of this issue?   I suspect that one task is trying
to clobber the file that another has just created or something of that
nature.
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120510/0d647cc2/attachment.htm>
