parallel-netcdf buffered I/O interface
Jim Edwards edwards.jim at gmail.com
Wed Aug 15 11:10:02 CDT 2012
Okay, so when do you need to call nfmpi_begin_indep_mode/
nfmpi_end_indep_mode?    It doesn't seem to
be entirely consistent anymore - is it?
On Wed, Aug 15, 2012 at 10:01 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Wed, Aug 15, 2012 at 09:32:56AM -0600, Jim Edwards wrote:
> > Hi Wei-keng,
> > Yes that looks like what I would need.   I have to think about the
> > independent aspect - currently i am using collective operations in almost
> > all cases.  The performance trade offs of independent vs collective
> > operations are not really clear to me.  Why no collective bputs?
> Aw, Wei-keng already replied.   Well, here's my answer, which says the
> same thing as Wei-keng but emphasises the "put it on a list" and
> "execute this list" aspects of these APIs.
> The 'buffered put' routines are a variant of the non-blocking
> routines.  These routines defer all I/O to the wait or wait_all
> routine, where all pending I/O requests for a given process are
> stitched together into one bigger request.
> So, issuing an I/O operation under these interfaces is essentially
> "put it on a list".  Then, "execute this list" can be done either
> independently (ncmpi_wait) or collectively (ncmpi_wait_all).
> A very early instance of these routines did the "put it on a list"
> collectively.  This approach did not work out so well for applications
> (like for example Chombo) where processes make a bunch of small
> uncoordinated I/O requests, but still have a clear part of their code
> where "collectively wait for everyone to finish" made sense.
> I hope you have enjoyed today's episode of Parallel-NetCDF history
> theater.
> ==rob
> > On Wed, Aug 15, 2012 at 9:18 AM, Wei-keng Liao
> > <wkliao at ece.northwestern.edu>wrote:
> > > > The  NC_EINSUFFBUF error code is returned from the bput call?
> > > I found a bug that 1.3.0 fails to return this error code. r1086 fixes
> this
> > > bug.
> > > >   If you get that error will you need to make that same bput call
> again
> > > after flushing?  But the other tasks involved in the same bput call who
> > > didn't have full buffers would do what?
> > > My idea is to skip the bput request when NC_EINSUFFBUF is returned.
> > > Flushing at the wait call will only flush those successful bput calls,
> so
> > > yes
> > > you need to make the same failed bput call again after flushing.
> > > Please note that bput APIs are independent. There is no "other tasks in
> > > the same bput call" issue.
> > > > I could use a query function and to avoid the independent write calls
> > > would do an mpi_allreduce on the max memory used before calling the
> > > mpi_waitall.  If the max is approaching the buffer size I would flush
> all
> > > io tasks. This is basically what I have implemented in pio with iput -
> I
> > > have a user determined limit on the size of the buffer and grow the
> buffer
> > > with each iput call, when the buffer meets (or exceeds) the limit on
> any
> > > task I call waitall on all tasks.
> > > This is a nice idea.
> > > Please let me know if the new query API below will be sufficient for
> you.
> > >   int ncmpi_inq_buffer_usage(int ncid, MPI_Offset *usage);
> > >   * "usage" will be returned with the current buffer usage in bytes.
> > >   * Error codes may be invalid ncid or no attached buffer found.
> > > Wei-keng
> > > > On Tue, Aug 14, 2012 at 10:07 PM, Wei-keng Liao <
> > > wkliao at ece.northwestern.edu> wrote:
> > > > Hi, Jim,
> > > > The usage of bput APIs is very similar to iput, except the
> followings.
> > > > 1. users must tell pnetcdf the size of buffer to be used by pnetcdf
> > > internally (attach and detach calls).
> > > > 2. once a bput API returns, user's buffer can be reused or freed
> > > (because the write
> > > >   data has been copied to the internal buffer.)
> > > > The internal buffer is per file (as the attach API requires an ncid
> > > argument.) It can be used to aggregate
> > > > requests to multiple variables defined in the file.
> > > > I did not implement a query API to check the current usage of the
> > > buffer. If this query is useful, we
> > > > can implement it. Let me know. But please note this query will be an
> > > independent call, so you
> > > > will have to call independent wait (nfmpi_wait). Independent wait
> uses
> > > MPI independent I/O, causing
> > > > poor performance, not recommended. Otherwise, you need an MPI reduce
> to
> > > ensure all processes know
> > > > when to call the collective wait_all.
> > > > You are right about flushing. The buffer will not be flushed
> > > automatically and all file I/O happens in wait_all.
> > > > If the attached buffer ran out of space, NC_EINSUFFBUF error code
> > > (non-fatal) will return. It can be
> > > > used to determine to call wait API, as described above. However, an
> > > automatic flushing would require an MPI
> > > > independent I/O, again meaning a poor performance. So, I recommend to
> > > make sure the buffer size is
> > > > sufficient large. In addition, if you let pnetcdf do type conversion
> > > between two types of different size
> > > > (e.g. short to int), you must calculate the size of attach buffer
> using
> > > the larger type.
> > > > If automatic flushing is highly desired, we can add it later.
> > > > Once the call to wait/wait_all returns, the internal buffer is marked
> > > empty.
> > > > Let me know if the above answers your questions.
> > > > Wei-keng
> > > > On Aug 14, 2012, at 2:04 PM, Jim Edwards wrote:
> > > > > No, the flush must happen in the nfmpi_wait_all.
> > > > > But does that call mark the buffer as empty?  I'll wait and bug
> > > > > Wei-keng.
> > > > > On Tue, Aug 14, 2012 at 12:56 PM, Rob Latham <robl at mcs.anl.gov>
> wrote:
> > > > > On Tue, Aug 14, 2012 at 12:52:46PM -0600, Jim Edwards wrote:
> > > > >> Hi Rob,
> > > > >> I assume that the same buffer can be used for multiple variables
> (as
> > > long
> > > > >> as they are associated with the same file).    Is there a query
> > > function so
> > > > >> that you know when you've used the entire buffer and it's time to
> > > flush?
> > > > > It does not appear to be so.  The only non-data-movement routines
> in
> > > > > the API are these:
> > > > > int ncmpi_buffer_attach(int ncid, MPI_Offset bufsize);
> > > > > int ncmpi_buffer_detach(int ncid);
> > > > > The end-user doesn't flush, I don't think.  I had the impression
> that
> > > once the
> > > > > buffer filled up, the library did the flush, then started filling
> up
> > > the buffer
> > > > > again.  This one I'll need Wei-keng to confirm.
> > > > > ==rob
> > > > >> Jim
> > > > >> On Tue, Aug 14, 2012 at 11:41 AM, Rob Latham <robl at mcs.anl.gov>
> > > wrote:
> > > > >>> On Tue, Aug 14, 2012 at 10:50:15AM -0600, Jim Edwards wrote:
> > > > >>>> No, I'm using iput and blocking get.   I'm doing my own
> buffereing
> > > layer
> > > > >>> in
> > > > >>>> pio.   I might consider using the bput functions - can you
> point me
> > > to
> > > > >>> some
> > > > >>>> documentation/examples?
> > > > >>> Sure.  It's too bad Wei-keng is on vacation this month, as he's
> the
> > > > >>> one who designed and implemented this new feature for pnetcdf
> 1.3.0.
> > > > >>> Wei-keng: i'm not expecting you to reply while on vacation.  I'm
> just
> > > > >>> CCing you so you know I'm talking about your work :>
> > > > >>> I think this might be the entire contents of our documentation:
> > > > >>> "A new set of buffered put APIs (eg. ncmpi_bput_vara_float) is
> added.
> > > > >>> They make a copy of the user's buffer internally, so the user's
> > > buffer
> > > > >>> can be reused when the call returns. Their usage are similar to
> the
> > > > >>> iput APIs. "
> > > > >>> Hey, check that out: Wei-keng wrote up a fortran example:
> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/trunk/examples/tutorial/pnetcdf-write-bufferedf.F
> > > > >>> There's also the C version:
> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/trunk/examples/tutorial/pnetcdf-write-buffered.c
> > > > >>> ==rob
> > > > >>>> On Tue, Aug 14, 2012 at 10:16 AM, Rob Latham <robl at mcs.anl.gov>
> > > wrote:
> > > > >>>>> Hi Jim
> > > > >>>>> You've been using the new 'bput/bget' routines, right?  Can you
> > > tell
> > > > >>>>> me a bit about what you are using them for, and what -- if any
> > > > >>>>> benefit they've provided?
> > > > >>>>> (Rationale: our program management likes to see papers and
> > > > >>>>> presentations, but the most valued contribution is 'science
> > > impact').
> > > > >>>>> Thanks
> > > > >>>>> ==rob
> > > > >>>>> Rob Latham
> > > > >>>>> Mathematics and Computer Science Division
> > > > >>>>> Argonne National Lab, IL USA
> > > > >>> Rob Latham
> > > > > Rob Latham
> > > > > Jim Edwards
> > > > > CESM Software Engineering Group
> > > > > National Center for Atmospheric Research
> > > > > Boulder, CO
> > > > > 303-497-1842
> > > > Jim Edwards
> Rob Latham
Jim Edwards
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120815/b54a6b78/attachment.html>
