mvapich, nonblocking build issue
Rob Latham robl at mcs.anl.gov
Mon Sep 12 14:12:47 CDT 2011
On Mon, Sep 12, 2011 at 02:33:38PM -0400, Brent Woodruff wrote:
> Thanks. Building MVAPICH2 versions is not a problem and I already have this working. I will advise our users that parallel-netcdf is not currently MVAPICH-1 compatible.
Well, the fix is easy enough: that one spot is all that needed cleaned
up.
apply svn revision 926
(http://trac.mcs.anl.gov/projects/parallel-netcdf/changeset/926)
and you'll have a pnetcdf that works with any mpi implementation, even
the mpi-1 based ones.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
