Compiled Success !!!! Thanks Regards, very thanks all members that list.
Varlei Everton Menconi
varlei at dge.inpe.br
Wed Jun 29 09:12:57 CDT 2011
Hi !!!
I make compile fromparallelNetCDF.
Thanks, very thanks all members by messages send-me.
Varlei
(varlei at dge.inpe.br)
INPE - Instituto Nacional de Pesquisas Espaciais
CEA - Ciências Espaciais e Atmosféricas
DGE - Divisão de Geofísica Espacial
Avenida dos Astronautas, 1758- Jardim Granja -Predio Sigma -Sala 41
Cep: 12227-010 - São Jose dos Campos - SP - Brasil
fone: (055) (012) 3208-6819
fax: (055) (012) 3208-6810
On 06/28/2011 01:05 PM, Varlei Everton Menconi wrote:
> Hi all members this list.;
> Wei-keng suggested:
> From your configure log, I can see the "configure" is still using f77.
> The problem is "configure" checks the environment variable "FC" instead of "F77".
> Can you try set "FC" to gfortran and let us know?
> By the way, here is the list of environment variables that can be set. (in tcsh)
> setenv CC gcc
> setenv CXX g++
> setenv FC gfortran
> setenv F90 gfortran
> setenv MPICC mpicc
> setenv MPICXX mpicxx
> setenv MPIF77 mpif77
> setenv MPIF90 mpif90
> Wei-keng
> I make the environment variables:
> #!/bin/bash
> SHELL=/bin/bash
> MAILTO=varlei at dge.inpe.br
> clear
> export CC=/usr/bin/gcc
> export CXX=/usr/bin/g++
> export FC=/usr/bin/gfortran
> export F90=/usr/bin/gfortran
> export MPICC=/usr/bin/mpicc
> export MPICXX=/usr/bin/mpiccxx
> export MPIF77=/usr/bin/mpif77
> export MPIF90=/usr/bin/mpif90
> printenv
> The return that command printenv it's attached file Lista3.txt.
> The variables to do correct values (conform show file).
> Then i try to compile with command follow.
> #!/bin/bash
> SHELL=/bin/bash
> clear
> printenv
> rm -fR /usr/local/parallelNetCDF/*.*
> ./configure --prefix=/usr/local/parallelNetCDF
> --enable-fortran --enable-mpi-io-test --with-mpi=/usr
> This log's that command into attached file LogCompiler3.txt
> Error still persist: /*"configure: error: F77 does not support
> "integer*8"*/
> Even with the parameter "--disable-fortran" in to line command,
> error still persist.
> I can't understand why.
> Jim Edwards suggest i tryed compile the code follow in my computer:
> > program test
> > integer*8 :: fred
> > end program
> I try to compile with the command gfortran-4.5. (using the line
> comand: gfortran-4.5 -o Teste Jim.f90 (source file with code) )
> ./Teste
> The compiled with sucess and without errors. I run the executable
> file and find execution with errors.
> I try the with symbolic link g77 (using the line comand: g77 -o
> Teste2 Jim.f90 (source file with code) ) ./Teste2
> I can't understand why,
> Thanks by your help.
> Varlei
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20110629/55d16014/attachment.htm>
More information about the parallel-netcdf
