Error try install parallel-NetCDF: configure: error: F77 does not	support "integer*8"
    Jim Edwards
    edwards.jim at gmail.com
    Tue Jun 28 11:15:37 CDT 2011
Look in the config.log for a record of what exactly is being built in the
integer*8 test and why it is failing.   It should be near the end of that
file.
On Tue, Jun 28, 2011 at 10:05 AM, Varlei Everton Menconi <varlei at dge.inpe.br
> wrote:
> Hi all members this list.;
> Wei-keng suggested:
> From your configure log, I can see the "configure" is still using f77.
> The problem is "configure" checks the environment variable "FC" instead of "F77".
> Can you try set "FC" to gfortran and let us know?
> By the way, here is the list of environment variables that can be set. (in tcsh)
> setenv CC     gcc
> setenv CXX    g++
> setenv FC     gfortran
> setenv F90    gfortran
> setenv MPICC  mpicc
> setenv MPICXX mpicxx
> setenv MPIF77 mpif77
> setenv MPIF90 mpif90
> Wei-keng
> I make the environment variables:
>     #!/bin/bash
>     SHELL=/bin/bash
>     MAILTO=varlei at dge.inpe.br
>     clear
>     export CC=/usr/bin/gcc
>     export CXX=/usr/bin/g++
>     export FC=/usr/bin/gfortran
>     export F90=/usr/bin/gfortran
>     export MPICC=/usr/bin/mpicc
>     export MPICXX=/usr/bin/mpiccxx
>     export MPIF77=/usr/bin/mpif77
>     export MPIF90=/usr/bin/mpif90
>     printenv
> The return that command printenv it's attached file Lista3.txt.
> The variables to do correct values (conform show file).
> Then i try to compile with command follow.
>         #!/bin/bash
>         SHELL=/bin/bash
>         clear
>         printenv
>         rm -fR /usr/local/parallelNetCDF/*.*
>         ./configure --prefix=/usr/local/parallelNetCDF --enable-fortran
> --enable-mpi-io-test --with-mpi=/usr
>         This log's that command into attached file LogCompiler3.txt
> Error still persist:    *"configure: error: F77 does not support
> "integer*8"*
> Even with the  parameter "--disable-fortran" in to line command,  error
> still persist.
> I can't understand why.
> Jim Edwards suggest i tryed compile the code follow in my computer:
> >       program test
> >       integer*8 :: fred
> >       end program
> I try to compile with the command gfortran-4.5.  (using the line comand:
> gfortran-4.5 -o Teste   Jim.f90 (source file with code) )    ./Teste
>    The compiled with sucess and without errors. I run the executable file
> and find execution with errors.
> I try the with symbolic link g77  (using the line comand:  g77 -o Teste2
> Jim.f90 (source file with code) )  ./Teste2
> I can't understand why,
> Thanks by your help.
> Varlei
>  (varlei at dge.inpe.br)
>  INPE - Instituto Nacional de Pesquisas Espaciais
>  CEA - Ciências Espaciais e Atmosféricas
>  DGE - Divisão de Geofísica Espacial
>  Avenida dos Astronautas, 1758- Jardim Granja -Predio Sigma -Sala 41
>  Cep: 12227-010 - São Jose dos Campos - SP - Brasil
>  fone:  (055) (012)  3208-6819
>  fax:   (055) (012)  3208-6810
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20110628/ed8b33e5/attachment.htm>
More information about the parallel-netcdf
