Help-me !!! Fwd: Help, Urgent please. Fwd: Error try install parallel-NetCDF: configure: error: F77 does not support "integer*8"
Jim Edwards
edwards.jim at gmail.com
Tue Jun 28 08:46:35 CDT 2011
Rajeev,
I think that your question has already been answered. You are using the
g77 compiler - you need to use gfortran.
Jim
On Tue, Jun 28, 2011 at 7:43 AM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> Did you try using gfortran instead of g77 as the Fortran compiler as I had
> said?
> Rajeev
> On Jun 28, 2011, at 8:41 AM, Varlei Everton Menconi wrote:
> > -------- Original Message --------
> > Subject: Help, Urgent please. Fwd: Error try install
> > Date: Fri, 24 Jun 2011 18:02:37 -0300
> > From: Varlei Everton Menconi <varlei at dge.inpe.br>
> > To: parallel-netcdf at mcs.anl.gov
> > Hello.
> > I need your help. urgent. I didn't complet the compilation of program.
> > In file REAME from package-source citate:
> > - Fortran routines will pass in a 64 bit integer for some parameters
> (those
> > corresponding to MPI_Offset type in the C routines). Declare those
> > parameters as 'integer(kind=MPI_OFFSET_KIND)'
> > How to and what file and parameters i do this settings ?
> > It's a possible send me samples of configuration.
> > This error:
> > Varlei
> > Subject: Error try install parallel-NetCDF: configure: error: F77
> > Date: Wed, 22 Jun 2011 19:15:23 -0300
> > CC: varlei at dge.inpe.br
> > Hello.
> > I tring to install parallel-netcdf.
> > I run the command
> > ./configure --prefix=/usr/local/parallelNetCDF --enable-fortran
> > --enable-mpi-io-test --with-mpi=/usr
> > The compile processing with sucess (look log this display compile
> > process into attach file) at error above show.
> > I would like know what cause this error and how to compile the program
> > parallelNetCDF.
> > The environment variables settings :
> > #!/bin/bash
> > SHELL=/bin/bash
> > MAILTO=varlei at dge.inpe.br
> > clear
> > # export USEFORTRAN=/usr/bin/fort77
> > export USEFORTRAN=/usr/bin/g77
> > # export USEFORTRAN=/usr/bin/ratfor
> > # export USEFORTRAN=/opt/intel/bin/ifort
> > # export MPICC=/usr/bin/mpicc
> > export MPICC=/usr/bin/mpicc.mpich2
> > export MPICXX=/usr/bin/mpic++.mpich2
> > export CC=/usr/bin/gcc
> > export CXX=/usr/bin/g++
> > export MPIF77=/usr/bin/mpif90.mpich2
> > export F77=$USEFORTRAN
> > export F90=$USEFORTRAN
> > export F95=$USEFORTRAN
> > I work with gnu-compilers (gfortran-4.5, gcc-4.5, g++-4.5) and intel
> > compilers version 12.0.4
> > (icc 12.0.4.00, icpc, ifortran-12.0.4)
> > I need yor help urgent.
> > Thanks by attention.
> > (São José dos Campos, SP, Brazil)
> > INPE - Instituto Nacional de Pesquisas Espaciais
> > CEA - Ciências Espaciais e Atmosféricas
> > DGE - Divisão de Geofísica Espacial
> > Avenida dos Astronautas, 1758- Jardim Granja -Predio Sigma -Sala 41
> > Cep: 12227-010 - São Jose dos Campos - SP - Brasil
> > fone: (055) (012) 3208-6819
> > fax: (055) (012) 3208-6810
> > <logCompileParallelNetCdf.txt>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20110628/e7de3d95/attachment.htm>
More information about the parallel-netcdf
