Help, Urgent please. Fwd: Error try install parallel-NetCDF: configure: error: F77 does not support "integer*8"
Rajeev Thakur
thakur at mcs.anl.gov
Fri Jun 24 16:04:34 CDT 2011
Why don't you use gfortran instead of g77.
Rajeev
On Jun 24, 2011, at 4:02 PM, Varlei Everton Menconi wrote:
> Hello.
> I need your help. urgent. I didn't complet the compilation of program.
> In file REAME from package-source citate:
> - Fortran routines will pass in a 64 bit integer for some parameters (those
> corresponding to MPI_Offset type in the C routines). Declare those
> parameters as 'integer(kind=MPI_OFFSET_KIND)'
> How to and what file and parameters i do this settings ?
> It's a possible send me samples of configuration.
> This error:
> Varlei
> -------- Original Message --------
> Subject: Error try install parallel-NetCDF: configure: error: F77 does not support "integer*8"
> Date: Wed, 22 Jun 2011 19:15:23 -0300
> From: Varlei Everton Menconi <varlei at dge.inpe.br>
> To: parallel-netcdf at mcs.anl.gov
> CC: varlei at dge.inpe.br
> Hello.
> I tring to install parallel-netcdf.
> I run the command
> ./configure --prefix=/usr/local/parallelNetCDF --enable-fortran
> --enable-mpi-io-test --with-mpi=/usr
> The compile processing with sucess (look log this display compile
> process into attach file) at error above show.
> I would like know what cause this error and how to compile the program
> parallelNetCDF.
> The environment variables settings :
> #!/bin/bash
> SHELL=/bin/bash
> MAILTO=varlei at dge.inpe.br
> clear
> # export USEFORTRAN=/usr/bin/fort77
> export USEFORTRAN=/usr/bin/g77
> # export USEFORTRAN=/usr/bin/ratfor
> # export USEFORTRAN=/opt/intel/bin/ifort
> # export MPICC=/usr/bin/mpicc
> export MPICC=/usr/bin/mpicc.mpich2
> export MPICXX=/usr/bin/mpic++.mpich2
> export CC=/usr/bin/gcc
> export CXX=/usr/bin/g++
> export MPIF77=/usr/bin/mpif90.mpich2
> export F77=$USEFORTRAN
> export F90=$USEFORTRAN
> export F95=$USEFORTRAN
> I work with gnu-compilers (gfortran-4.5, gcc-4.5, g++-4.5) and intel
> compilers version 12.0.4
> (icc 12.0.4.00, icpc, ifortran-12.0.4)
> I need yor help urgent.
> Thanks by attention.
> (São José dos Campos, SP, Brazil)
> INPE - Instituto Nacional de Pesquisas Espaciais
> CEA - Ciências Espaciais e Atmosféricas
> DGE - Divisão de Geofísica Espacial
> Avenida dos Astronautas, 1758- Jardim Granja -Predio Sigma -Sala 41
> Cep: 12227-010 - São Jose dos Campos - SP - Brasil
> fone: (055) (012) 3208-6819
> fax: (055) (012) 3208-6810
> <logCompileParallelNetCdf.txt>
More information about the parallel-netcdf
