Error try install parallel-NetCDF: configure: error: F77 does not support "integer*8"
Varlei Everton Menconi
varlei at dge.inpe.br
Wed Jun 22 17:15:23 CDT 2011
Hello.
I tring to install parallel-netcdf.
I run the command
./configure --prefix=/usr/local/parallelNetCDF --enable-fortran
--enable-mpi-io-test --with-mpi=/usr
The compile processing with sucess (look log this display compile
process into attach file) at error above show.
I would like know what cause this error and how to compile the program
parallelNetCDF.
The environment variables settings :
#!/bin/bash
SHELL=/bin/bash
MAILTO=varlei at dge.inpe.br
clear
# export USEFORTRAN=/usr/bin/fort77
export USEFORTRAN=/usr/bin/g77
# export USEFORTRAN=/usr/bin/ratfor
# export USEFORTRAN=/opt/intel/bin/ifort
# export MPICC=/usr/bin/mpicc
export MPICC=/usr/bin/mpicc.mpich2
export MPICXX=/usr/bin/mpic++.mpich2
export CC=/usr/bin/gcc
export CXX=/usr/bin/g++
export MPIF77=/usr/bin/mpif90.mpich2
export F77=$USEFORTRAN
export F90=$USEFORTRAN
export F95=$USEFORTRAN
I work with gnu-compilers (gfortran-4.5, gcc-4.5, g++-4.5) and intel
compilers version 12.0.4
(icc 12.0.4.00, icpc, ifortran-12.0.4)
I need yor help urgent.
Thanks by attention.
(São José dos Campos, SP, Brazil)
(varlei at dge.inpe.br)
INPE - Instituto Nacional de Pesquisas Espaciais
CEA - Ciências Espaciais e Atmosféricas
DGE - Divisão de Geofísica Espacial
Avenida dos Astronautas, 1758- Jardim Granja -Predio Sigma -Sala 41
Cep: 12227-010 - São Jose dos Campos - SP - Brasil
fone: (055) (012) 3208-6819
fax: (055) (012) 3208-6810
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20110622/b06789d7/attachment.txt>
More information about the parallel-netcdf
