File locking failed in ADIOI_Set_lock
Rob Ross
rross at mcs.anl.gov
Mon Sep 27 15:37:43 CDT 2010
Thanks. -- Rob
On Sep 27, 2010, at 3:26 PM, John Michalakes wrote:
> It's not dumping a trace (the code is calling MPI_ABORT at this
> point and so it's dying cleanly). I'll see what I can get for you. -
> John
> On 9/27/2010 2:19 PM, Rob Ross wrote:
>> Ugh. Any chance you could get a stack dump from where this is
>> happening? -- Rob
>> On Sep 27, 2010, at 3:17 PM, John Michalakes wrote:
>>> Thanks all for your responses and your suggestions. I have re-
>>> engineered the code to use only collective I/O but I am still
>>> seeing the error I first wrote about:
>>> File locking failed in ADIOI_Set_lock(fd 16,cmd F_SETLKW/7,type
>>> F_WRLCK/1,whence 0) with return value FFFFFFFF and errno 26.
>>> If the file system is NFS, you need to use NFS version 3, ensure
>>> that the lockd daemon is running on all the machines, and mount
>>> the directory with the 'noac' option (no attribute caching).
>>> ADIOI_Set_lock:: Function not implemented
>>> ADIOI_Set_lock:offset 65492, length 1980
>>> So this probably isn't an effect from using the independent API
>>> after all (drat!). I will try some of the other suggestions now
>>> -- first of which will be to upgrade to the latest pNetCDF on this
>>> machine. I'm not sure I'll be able to switch over to MPICH2/romio
>>> but I'll look into that as well.
>>> Thanks,
>>> John
>>> On 9/24/2010 9:53 AM, Wei-keng Liao wrote:
>>>> Hi, John,
>>>> Rob is right, turning off data sieving just avoids the error
>>>> messages and may
>>>> significantly slow down the performance (if your I/O is non-
>>>> contiguous and
>>>> only calls non-collective.)
>>>> On Lustre, you need collective I/O to get high I/O bandwidths.
>>>> Even if your
>>>> write request from each process is already large and contiguous,
>>>> non-collective
>>>> write will still give you poor results. This is not the case on
>>>> other file
>>>> systems, e.g. GPFS.
>>>> Is there an option to turn on collective I/O in WRF and PIO?
>>>> If non-collective I/O is the only option (due to the irregular data
>>>> distribution), then non-blocking I/O is another solution. In
>>>> pnetcdf 1.2.0, non-blocking I/O can aggregate multiple
>>>> non-collective requests into a single collective one. However, this
>>>> approach requires changes to the pnetcdf calls in the I/O library
>>>> used by WRF and PIO. The changes should be very simple, though.
>>>> In general, I would suggest Lustre users to seek all opportunity
>>>> to call
>>>> collective I/O.
>>>> Wei-keng
>>>> On Sep 24, 2010, at 9:44 AM, Rob Latham wrote:
>>>>> On Fri, Sep 24, 2010 at 07:49:06AM -0600, Mark Taylor wrote:
>>>>>> Hi John,
>>>>>> I've had a very similar issue a while ago on several older Lustre
>>>>>> filesystems at Sandia, and I can confirm that setting those
>>>>>> hints did
>>>>>> allow the code to run
>>>>> if you turn off data sieving then there will be no more lock
>>>>> calls.
>>>>> Depending on how your application partitions the arrays, that
>>>>> could be
>>>>> fine, or it could result in a billion 8 byte operations.
>>>>>> (but I could never get pnetcdf to be any faster
>>>>>> than netcdf).
>>>>> Unsurprising, honestly. If you are dealing with Lustre, then
>>>>> you must
>>>>> both use an updated ROMIO and use collective I/O.
>>>>> Here is the current list of MPI-IO implementations that work
>>>>> well with
>>>>> Lustre:
>>>>> - Cray MPT 3.2 or newer
>>>>> - MPICH2-1.3.0a1 or newer
>>>>> - and that's it.
>>>>> I think the OpenMPI community is working on a re-sync with MPICH2
>>>>> romio. I also think we can stitch together a patch against
>>>>> OpenMPI if
>>>>> you really need the improved lustre driver. I'm not really in
>>>>> patch-generating mode right now, but maybe once i'm back in the
>>>>> office
>>>>> I can see how tricky it will be.
>>>>>> This was with CAM, with pnetcdf being called by PIO, and
>>>>>> PIO has a compiler option to turn this on, -DPIO_LUSTRE_HINTS.
>>>>>> However, on Sandia's redsky (more-or-less identical to
>>>>>> RedMesa), I just
>>>>>> tried these hints and I am also getting those same error
>>>>>> messages you
>>>>>> are seeing. So please let me know if you get this resolved.
>>>>> I can't think of any other code paths that use locking, unless
>>>>> your
>>>>> system for some reason presents itself as nfs.
>>>>> That's why rajeev suggested prefixing with lustre:
>>>>> Unfortunately, that
>>>>> won't help: it has only been since March of this year that (with
>>>>> community support) the Lustre driver in MPICH2 passed all the
>>>>> ROMIO
>>>>> tests, and now we need to get that into OpenMPI.
>>>>> ==rob
> John Michalakes
> National Renewable Energy Laboratory
> 1617 Cole Blvd.
> Golden, Colorado 80401
> Phone: 303-275-4297
> Fax: 303-275-4091
> John.Michalakes at nrel.gov
More information about the parallel-netcdf
