collective i/o on zero-dimensional data
Maxwell Kelley
kelley at giss.nasa.gov
Mon Oct 4 18:42:07 CDT 2010
Hello,
Some code I ported from a GPFS to a Lustre machine was hit by the
performance effects of switching back and forth between collective mode
for distributed data and independent mode for non-distributed data.
Converting the writes of non-distributed data like zero-dimensional (0D)
variables to collective mode was straightforward, but with a small
wrinkle. Since the start/count vectors passed to put_vara_double_all
cannot be used to indicate which process possesses the definitive value of
a 0D variable, I could only get correct results by ensuring that this
datum is identical on all processes. Can I count on put_vara_double_all
always behaving this way, or could future library versions refuse to write
0D data in collective mode? BTW the return code did not indicate an error
when process-varying 0D data was passed to put_vara_double_all.
Grouping independent-mode writes could reduce the number of switches
between collective and independent mode but would require significant code
reorganization so I tried the all-collective option first. I could also
declare 0D variables as 1D arrays of length 1.
Before going any further, I should also ask about the recommended method
for writing a 0D variable. Collective I/O? Or independent I/O with
system-specific MPI hints (I haven't explored the MPI hints)? Or should I
use independent mode for all data, including the distributed arrays?
-Max
More information about the parallel-netcdf
