possible bug in nfmpi_enddef?
Jim Edwards edwards.jim at gmail.com
Fri May 21 15:31:05 CDT 2010
Hi Rob,
It's pnetcdf-1.1.1  Art is seeing it on jaguar and I am reproducing it on
bluefire.
On Fri, May 21, 2010 at 2:25 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Fri, May 21, 2010 at 01:23:02PM -0600, Jim Edwards wrote:
> > I am trying to do
> > rocde = nfmpi_redef(file)
> > rcode = nfmpi_put_att(cpl_io_file,pio_global,"file_version",version)
> > rcode = nfmpi_enddef(cpl_io_file)
> > But this results in
> >  Memory allocation (malloc) failure
> placing a single attribute on the dataset *might* result in growing
> the header.  You'd know it if you ever hit that: performance would go
> straight down the toilet.   If the header grows enough that you have
> to shuffle all the other variables down, pnetcdf will do so at 4k (!)
> at a time.
> So, that's one place that allocates memory in the redef case, but
> there really aren't 4k bytes of memory to spare?  Seems unlikely.
> Do you maybe have a core file or a backtrace of where this happens?
> Is this on bluefire or bgp or something else?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100521/dd4293be/attachment.htm>
