Problems with PGI and 1.1.1
Gerry Creager gerry.creager at tamu.edu
Tue May 18 17:24:58 CDT 2010
I'll try that tomorrow!
Thanks!
gerry
On 5/18/10 7:22 AM, David Robertson wrote:
> Hi Gerry and Rob,
> On 5/17/2010 3:00 PM, Rob Latham wrote:
>> On Mon, May 17, 2010 at 01:36:33PM -0400, David Robertson wrote:
>>> I have tried to run nc_test in the totalview debugger. With MPICH
>>> and PGI 10.5, the segfault occurs at line 638 of src/lib/var.c:
>>> (void) strncpy(name, varp->name->cp, varp->name->nchars);
>> ah, i thought that looked familiar. Can you try with the attached
>> patch? It's also r805 and r807 in SVN.
> The patch worked perfectly. Thanks! Is there any reason to recompile
> parallel-netcdf with my other compiler (ifort and gfortran) and MPI
> implementations that compiled and tested successfully before the patch?
> Thanks,
> Dave
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
