Problems with PGI and 1.1.1
David Robertson robertson at marine.rutgers.edu
Tue May 18 07:22:12 CDT 2010
Hi Gerry and Rob,
On 5/17/2010 3:00 PM, Rob Latham wrote:
> On Mon, May 17, 2010 at 01:36:33PM -0400, David Robertson wrote:
>> I have tried to run nc_test in the totalview debugger. With MPICH
>> and PGI 10.5, the segfault occurs at line 638 of src/lib/var.c:
>> (void) strncpy(name, varp->name->cp, varp->name->nchars);
> ah, i thought that looked familiar.  Can you try with the attached
> patch?  It's also r805 and r807 in SVN.
The patch worked perfectly. Thanks! Is there any reason to recompile
parallel-netcdf with my other compiler (ifort and gfortran) and MPI
implementations that compiled and tested successfully before the patch?
Dave
